Old 07-30-2008, 01:13 PM   #1
mikaserla   mikaserla is offline
vibes
I seem to have vibes from the range of 3000 rpms to 5500 rpms. Higher than that they seem to go away. Which is good because I usually cruise at 6500rpms.
Does anyone else have vibes in this range.
I have a gy200-2. Do you think a gy5 with a counter balanced engine make the vibes go away. Does the counter balancing make zero vibes.
Old 07-30-2008, 03:05 PM   #2
fatboy250   fatboy250 is offline
The two back engine bolts are likely the culprit. You may have to go the Gorilla Glue route to reduce the vibes, I did.
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
1995 Kawasaki Concours (ZG1000)
Old 07-30-2008, 03:15 PM   #3
I did replace the two back bolts because they broke. It doesn't vibe at above 5500 rpms so most of the time It's pretty smooth.
I have heard on this site that those with the counterbalance engines also receive some vibes so I don't know how much of a difference it would make by having this feature.
Old 07-30-2008, 06:09 PM   #4
alonzo   alonzo is offline
yes it does. there is very little vibration on the gy5 I have tried a gy 2 type and the balanced engine makes a world of difference in the two bikes.
