Old 07-21-2008, 11:47 AM   #16
jwe   jwe is offline
I think the green looks sweet.
I have to find the rest of the plastic I need before I can find out tho.
Old 07-21-2008, 12:32 PM   #17
coleary15   coleary15 is offline
Send a message via AIM to coleary15
hey jwe...how did u get that awesome metallic green?
Old 07-21-2008, 02:16 PM   #18
jwe   jwe is offline
That is a photoshopped image. I did it to see how my bike would look green and thought I would share it.
Old 07-21-2008, 10:07 PM   #19
jwe   jwe is offline
Went for a longer ride today with a friend (he was on a 600 suzuki), to compare speedometer readings. Mine matched his +/- 1mph.
Total trip was 20 miles. Bike did great and RPMs seemed to be around 7500 at 60mph. (update katoranger)
However
At about mile 18 I noticed my TACH was not working, at mile 19 I noticed it was working again but was reading high. Upon turning the bike off the TACH needle stayed at 3000 rpm :(
So I gently tapped the side of the TACH - needle fell off.
Upon closer inspection the part of the needle that slides over the square "piece" that rotates was broken (half missing). :(
Old 07-22-2008, 09:24 AM   #20
Guest
Posts: n/a
It sounds to me like you have a gray market seat. That is a shame because those seats are nowhere near as comfortable as the ones bearing the Lifan name.
The sooner these gray market seats are off our bikes, the better!!!
psst ~ I'm just kidding!
Old 07-23-2008, 08:36 PM   #21
jwe   jwe is offline
had me for a second
Rode the bike to work today, nice day for riding except for the wind, I really need to get a windshield.
Took my cover off the other day to check my front sprocket.
Front = 17 tooth
Rear = 46 tooth
Painted spare white side covers black, will post pics later.
Old 07-25-2008, 03:36 PM   #22
jwe   jwe is offline
On the way home yesterday I inadvertently got the bike over 60MPH on a downhill stretch and the front wheel started (i don't want to say wobble so) to get a little "squirrely".
I have checked and tightened the spokes.
Any thought?
Old 07-25-2008, 04:12 PM   #23
katoranger's Avatar
It may just be the tires. Also make sure you have the correct tire pressure.
Allen
Old 07-25-2008, 05:04 PM   #24
AZ200cc   AZ200cc is offline
can You wobble the wheel by hand?
<br />2001 Suzuki DR200SE<br />1997 Suzuki RM250 YIKES<br />1995 Yamaha Breeze 125 daughters<br />1991 Honda XR80r Restored<br />maybe a 2003 Yamaha TTR90
Old 07-25-2008, 05:35 PM   #25
Cal25   Cal25 is offline
I had a difficult time getting the stock front tire to seat in the propper location on the rim. Had a spot on the tire thad rode a little lower in the rim. But my problem was more of a hop than a wobble.
Old 07-25-2008, 10:35 PM   #26
jwe   jwe is offline
Yes. If I am going 50+ (haven't tried it all speeds) and pull the handlebars to either side the same thing happens, which in turn makes me quit pulling so that I don't wreck it.
08 AL LF200-GY5
Old 07-26-2008, 08:34 PM   #27
jwe   jwe is offline
Exhaust Prob
Going over the bike tonight and noticed 1 minor problem and 1 major one.
Minor:
upper left side of air box has a hole with metal insert for mounting but
there is no place to mount it, as in no hole for a bolt to be used in ??
Major:
I had noticed some black stuff on the right side of the starter before but
had attributed it to chain lube "spraying" off. However, tonight I noticed
the clamp around the muffler where the 2 sections meet was a little loose
so I tightened it up, started the bike and poof, there is exhaust shooting
out. It is shooting out right at the motor and starter.
How can one fix this??
08 AL LF200-GY5
Old 07-29-2008, 09:17 PM   #28
jwe   jwe is offline
Did my first MPG check today :(
only getting 51 MPG
any thoughts?
Old 07-30-2008, 09:01 AM   #29
katoranger's Avatar
How are riding it? Off-road. City traffic.
I ride in suburban conditions so I am moving most of the time. 73mpg after filter and exhuast mods with 108 main jet.
Allen
Old 07-30-2008, 11:08 AM   #30
jwe   jwe is offline
I am using it to commute. 10 miles, 2 lane road, 55 most of the time with 2 stop lights.
Any thoughts would be great.
