Exhaust Leak Help
I did a search and didn't find this exact problem.
I posted this under my original Topic but don't think it was noticed. I had noticed some black stuff on the right side of the starter before, but had attributed it to chain lube "spraying" off. However, tonight I noticed the clamp around the muffler where the 2 sections meet was a little loose so I tightened it up, started the bike and there is exhaust shooting out. It is shooting out right at the motor and starter. How can one fix this??
08 AL LF200-GY5 |
Mine does this too. It helped a little when I put a new gasket in and coated it with Ultra Black RTV sealant, as Bruce from EJ Cycles suggested. I think it's a common problem with these bikes.
You can also get a hose clamp and tighten up on the pipe behind the stock clamp - double your chances of stopping exhaust blowing through. |
Can you make a flange from a softer, thin metal?
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
To bad I cant find something like this (EasySeal Stainless Steel Clamp) to fit as I have thought this would be very useful at that exhaust point.
Sadly they dont seem to come any smaller than 2" diameter. |
#5 | |
I haven't taken it all the way apart yet so I am not aware of what is there. Thanks everyone for your input. I will see what I can do. Woohoo, not a newbie anymore 8) |
Removed. Error.
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
