Old 07-17-2008, 03:24 PM   #16
theENIGMATIC   theENIGMATIC is offline
Thanks Squish!
Old 07-18-2008, 02:40 AM   #17
monkeyboy   monkeyboy is offline
My 17t just came in the mail today! After some weekend camping I'm gonna slap 'er on. I'm currently running stock 15/50 and it'll do 65mph WOT up a slight grade...I'm 180, 6'. I just want to be able to hit 60 at an rpm that doesn't rattle my fillings out! Anyone else running 17/50?
http://stores.ebay.com/PCC-MOTOR
Got the 17t from there.
2005 Diamo LS200
2009 WR250R
2010 Motobike Hyper
Old 07-18-2008, 03:46 PM   #18
fatboy250   fatboy250 is offline
I believe my front is 17. I replaced the rear 56 with a 49. Tops now with me at 250lbs is about 62mph. I will be replacing the rear tire soon with a bigger/taller street tire. It should be good for anothter few mph.
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
1995 Kawasaki Concours (ZG1000)
Old 07-21-2008, 12:15 PM   #19
jwe   jwe is offline
Originally Posted by kens97sto171
I got my 46t rear sproket from Bruce at EJ Cycles.
I can run 65-70 no problem... This was the single BIGGEST positive thing I did to the bike. I should have done it right after I got the bike. I can run 60-65MPH at 25-30% throttle now.. instead of WOT......
I just got my 200gy-5 out on the road this weekend and I could only get it up to around 60mph. I looked at the rear sprocket and it looks like it says 46-28 on it. So I am assuming that it is a 46 tooth sprocket with a 428 chain.
Does this sound right?
Should I be getting a better top speed?
Should I change my rear sprocket?
Old 07-21-2008, 12:47 PM   #20
katoranger's Avatar
What rpm were you turning?
It may be that your bike is leaning out and won't rev high enough to go any faster.
Allen
Old 07-21-2008, 02:19 PM   #21
jwe   jwe is offline
When I topped out it was only running at about 5000 rpm.
I had moved the c clip to the bottom notch.
Old 07-21-2008, 02:55 PM   #22
katoranger's Avatar
I run about 8500rpm topped out in 5th.
I bet you are running too lean yet. Take it out run it too top speed in 5th gear and then shut the bike off. Pull off the road and pull out the sparkplug. Note the color on the plug. Light or white will indicate lean.
Also the opposite may be too rich and it is choking out and not revving.
Allen
Old 07-26-2008, 02:16 AM   #23
Holy Guacamole 17t/50t from a 15t/50t is a nice improvement! I still have a 1st gear that will pop the front end up but 5th gear gives me a more comfy 60 and EVERY gear has more pull in it...sweet!
Problem: chain too tight and wheel is adjusted as far in as it will go.
Problem: I still want less rpms at 60.
Problem: Axle bolt and nut are so soft they need replacement.
So I'm gonna order a 46t rear for street. When trail time comes I could just swap the 17t front for the stock 15t front.
Will a 46t rear require me to buy a new chain?
2005 Diamo LS200
2009 WR250R
2010 Motobike Hyper
Old 07-26-2008, 08:48 AM   #24
katoranger's Avatar
You will need to remove a couple links for the 46t sprocket.
The 17/46 will give you a nice on-road setup and you will be able to do some light off-road too.
Allen
Old 07-26-2008, 08:50 PM   #25
Monkeyboy,
That's what I said when I got my 17 tooth.
IronFist
The "chain" of command is used for beating spammers.
Old 08-11-2008, 10:59 AM   #26
I gave her a facelift yesterday. New, shorter, stouter mirrors; new low profile turnsignals; oil change which smoothed out my shifts (amsoil 1040 cycle); hilarious monkey-man decals (I'm a tree climber); real bark busters; fresh handlebar pad (old one was rubber and like 5 pounds!); and most importantly...a 45 tooth rear sprocket!
With these simple upgrades I feel like I went from a toy to a motorcycle. Stock mirrors moved in the wind. The old blinkers were boxy and cheap (and broken. The oil was dirty to say the least. The stock barkbusters did nothing but bust because there's no reinforcement behind them and the plastic was brittle. The biggest improvement was that 45t rear sprocket. My existing chain from original 15/50 fits perfectly on this 17/45 with no link removal.
Last night on a two hour tour the bike just hauled a@#. I jumped right on the interstate and ran 65 mph along with the rest of traffic right into downtown Seattle at about 3/4 throttle...it felt weird! They're pretty squirrly at those sustained speeds but just manageable. 1st gear in the city is not only useable now but still low enough to pull the front wheel off the ground with no clutch slip. 17/45ish is a very nice ratio! I have a 40t and new chain as well but not sure if I need to go that tall. I suppose 65 mph at 1/4-1/2 throttle would be even better. Seems a sprcket as small as a 40t would cause major chain drag on the swing arm, anyone run into that?
2005 Diamo LS200
2009 WR250R
2010 Motobike Hyper
Old 08-11-2008, 12:08 PM   #27
chinaguy   chinaguy is offline
Update on mine (HSUN GY 200)
Installed a new 44T rear sprocket. The original set-up was 17/56. Now, at 17/44 it runs really great! I originally ordered a 46T, but the dealer I ordered it from got a 44.... probably sold out of 46s. Anyway, I think this new gearing is working real well; still plenty of power, but not reving so high at 60mph.
I also stuffed a piece of rag in the blinker beeping box to quiet the blinkers a little. It's a trick I read on here, posted by another member. That works great too.... much quieter, but you can still hear the signal.
Old 08-11-2008, 05:14 PM   #28
Almost wish mine did have the blinker beep...sometimes I go 2 or 3 miles before I realize the blinker's on!!
2005 Diamo LS200
2009 WR250R
2010 Motobike Hyper
Old 08-11-2008, 05:37 PM   #29
I wanted to keep a little "beep", but it originally sounded like a large truck backing up. It's just about right now. I have lights on the speedometer that blink left or right too as a reminder.
Old 08-12-2008, 02:22 AM   #30
Gave the 17t/45t another highway run tonight...about 20 miles. Learned a good tuck will give you another 5 miles an hour!
2005 Diamo LS200
2009 WR250R
2010 Motobike Hyper
