#16 |
Thanks Squish!
#17 |
My 17t just came in the mail today! After some weekend camping I'm gonna slap 'er on. I'm currently running stock 15/50 and it'll do 65mph WOT up a slight grade...I'm 180, 6'. I just want to be able to hit 60 at an rpm that doesn't rattle my fillings out! Anyone else running 17/50?
http://stores.ebay.com/PCC-MOTOR Got the 17t from there.
2005 Diamo LS200 2009 WR250R 2010 Motobike Hyper |
#18 | |
2008 Jonway MC-70-150 2007 Roketa DB-07B (RSM-200E) 2006 Roketa DB-07A (RSX-200E) 1995 Kawasaki Concours (ZG1000) |
#19 | |
Does this sound right? Should I be getting a better top speed? Should I change my rear sprocket? |
#20 |
What rpm were you turning?
It may be that your bike is leaning out and won't rev high enough to go any faster. Allen
#21 |
When I topped out it was only running at about 5000 rpm.
I had moved the c clip to the bottom notch. |
#22 |
I run about 8500rpm topped out in 5th.
I bet you are running too lean yet. Take it out run it too top speed in 5th gear and then shut the bike off. Pull off the road and pull out the sparkplug. Note the color on the plug. Light or white will indicate lean. Also the opposite may be too rich and it is choking out and not revving. Allen
#23 |
Holy Guacamole 17t/50t from a 15t/50t is a nice improvement! I still have a 1st gear that will pop the front end up but 5th gear gives me a more comfy 60 and EVERY gear has more pull in it...sweet!
Problem: chain too tight and wheel is adjusted as far in as it will go. Problem: I still want less rpms at 60. Problem: Axle bolt and nut are so soft they need replacement. So I'm gonna order a 46t rear for street. When trail time comes I could just swap the 17t front for the stock 15t front. Will a 46t rear require me to buy a new chain?
#24 |
You will need to remove a couple links for the 46t sprocket.
The 17/46 will give you a nice on-road setup and you will be able to do some light off-road too. Allen
#25 |
Monkeyboy,
That's what I said when I got my 17 tooth. ![]()
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
#26 |
I gave her a facelift yesterday. New, shorter, stouter mirrors; new low profile turnsignals; oil change which smoothed out my shifts (amsoil 1040 cycle); hilarious monkey-man decals (I'm a tree climber); real bark busters; fresh handlebar pad (old one was rubber and like 5 pounds!); and most importantly...a 45 tooth rear sprocket!
With these simple upgrades I feel like I went from a toy to a motorcycle. Stock mirrors moved in the wind. The old blinkers were boxy and cheap (and broken ![]() Last night on a two hour tour the bike just hauled a@#. I jumped right on the interstate and ran 65 mph along with the rest of traffic right into downtown Seattle at about 3/4 throttle...it felt weird! They're pretty squirrly at those sustained speeds but just manageable. 1st gear in the city is not only useable now but still low enough to pull the front wheel off the ground with no clutch slip. 17/45ish is a very nice ratio! I have a 40t and new chain as well but not sure if I need to go that tall. I suppose 65 mph at 1/4-1/2 throttle would be even better. Seems a sprcket as small as a 40t would cause major chain drag on the swing arm, anyone run into that?
#27 |
Update on mine (HSUN GY 200)
Installed a new 44T rear sprocket. The original set-up was 17/56. Now, at 17/44 it runs really great! I originally ordered a 46T, but the dealer I ordered it from got a 44.... probably sold out of 46s. Anyway, I think this new gearing is working real well; still plenty of power, but not reving so high at 60mph. I also stuffed a piece of rag in the blinker beeping box to quiet the blinkers a little. It's a trick I read on here, posted by another member. That works great too.... much quieter, but you can still hear the signal. |
#28 |
Almost wish mine did have the blinker beep...sometimes I go 2 or 3 miles before I realize the blinker's on!!
#29 |
I wanted to keep a little "beep", but it originally sounded like a large truck backing up. It's just about right now. I have lights on the speedometer that blink left or right too as a reminder.
#30 |
Gave the 17t/45t another highway run tonight...about 20 miles. Learned a good tuck will give you another 5 miles an hour!
