What are the chances an RX3S ECU will work in my SG400?
Looking to get rid of the flat spot at cruising speeds. Easiest way to do that for Benelli was to buy an ECU that wasn't modified for CARB/EPA requirements. Finding an RE3 ECU on aliexpress is impossible, but the RZ3S used the same engine. What are the chances of it working I wonder...
Charlie. |
I would think it would work. See if the part numbers are the same.
Hi Charlie,
You're correct that the Benelli RE3 and RZ3S share the same engine platform, which could mean their ECUs are interchangeable. However, there are a few things to keep in mind: Mapping Differences: Even if the engines are the same, the RZ3S ECU might have different fuel or ignition maps due to regional regulations or intended usage. Compatibility: Check the ECU part numbers and connectors to ensure physical and electronic compatibility. Risk of Damage: An incompatible ECU could harm the engine or other components, so proceed cautiously. |
