Old 11-06-2024, 07:09 AM   #16
Mumen Rider   Mumen Rider is offline
Mumen Rider's Avatar
KTM rear brake guards do not bolt up to the caliper the spacing is different by ~2mm. You have to switch over to the OE Brembo caliper to use it.
KTM lower chain guide guards do fit BUT do not contour to the rear swingarm correctly so the tabs can still bend.
I used a KTM kickstand spring and it works better than the OE spring, it's shorter and keeps tension when in the up position.
Take your calipers apart and grease the slide pins! My slide pins had dabs of grease around the rubber boots which made me think the pin had been greased but that is NOT the case.
Old 11-06-2024, 12:34 PM   #17
Dirtbike2025   Dirtbike2025 is offline
Hello anyone who has this bike how tall is it? If you set the suspension settings to lower can you flat foot? It looks tall and I don’t want to tippy toe
Old 11-06-2024, 03:55 PM   #18
The seat height is listed on the previous page. You won't be lowering the seat height without buying a different rear link. If you are under 6' you will not be flat footing this dirt bike.
Old 11-06-2024, 04:24 PM   #19
How about adjusting the suspension sag to soft and then sitting on the bike. I can flat foot the Templar x-250 no issue
Old 11-08-2024, 07:16 AM   #20
mark hall   mark hall is offline
Wow.. this Pallidin looks Great!! For only $300 more than the Lifan KPX250! Hmm.. decisions.. Love my KPX..
Old 11-08-2024, 07:26 AM   #21
Is the drag link weldable cast steel like the Lifan? The Pallidin likely is Aluminum.
Old 11-08-2024, 06:20 PM   #22
Trail report
I decided to take the Paladin on my local single track loop. Rain is coming, so I got this ride in.... I ran through some mud after this shot, but the Paladin performed flawlessly through the mud and slippery stuff. Amazed at the quality. No issues whatsoever.
At least now, under 40 miles...
No matter where you go, there you are
Old 11-08-2024, 06:34 PM   #23
Thumper can you tippy toe? How does it compare to the Templar x 250
Old 11-08-2024, 10:34 PM   #24
Can someone please for the love of god post a video of them sitting on the bike and adjusting the suspension so we can see how tall it is
Old 11-08-2024, 11:29 PM   #25
onthefly   onthefly is offline
I'll take some videos tomorrow. I am 6'6 so that is what brought me to this bike, I flat foot it. I'll get someone else that isn't a freak of nature to sit on it for comparison.
Old 11-09-2024, 12:14 AM   #26
It sits an inch higher than the Templar X 250, why is it so hard to understand this? If you are not 6+ you won't be flat footing the Paladin.
Old 11-09-2024, 02:30 AM   #27
On the fly thank you! This guy is on the Templar 250 he is 5”7 and touches flat foot with adjusted pre load
Start video at 16.15 you can see him sit on bike
Old 11-09-2024, 02:39 AM   #28
That's the base model, it's a lot lower.
Old 11-09-2024, 03:41 AM   #29
The lower rear shock mount has long fork legs and there is plenty of room to drill new mounting holes to lower the bike that way as discussed in the Templar resource guide. I've already responded by message on this.
Maybe someone will find a compatible lowering link instead.
I can't full flatfoot (5'10"), but the bike is so stable off road it isn't an issue for me. I think it is not quite as tall as the Templar X, or the stability makes me feel like it isn't as tall. The suspension/frame feels more taught than Templar. Also, the rear shock on mine came with lots of preload dialed up. I thought it might be too much, but it works well stiffened up. I LIKE it!!!
Old 11-09-2024, 02:49 PM   #30
@mumen- the bad model is 1.2 inches lower than the x model and the guy is 5”7 I am 5”10.
@ thumper- can you take a video of you sitting on the bike and adjust the pre load to soft so we can see the height and how close you are from flat foot?
I don’t understand people have this bike but they are posting NO videos and very little information..: POST VIDEOS for the community
