#16 |
Doesn't get much better than that. Did the stumble go away? What manual are you referring to? The one that came from CSC with the bike or a Nibbi manual? Here's what I got for Nibbi:
#17 |
Update.
It's too rich. But like a hair too rich in the midrange. Random stumble coming off idle. Sounds fat like a tractor. Going to try two things. First. Raise the needle clip from position 3 to 2. If that is unfavorable I'm going to try the factory combo from the PE28FL. This would lower the main jet to 112 and change the needle clip to position 4. My manual looks different than that one. I have the factory settings for the "PE**FL" lineup and the clamp on lineup. |
#18 |
Update. That worked. No stumbling, no gassy smell.
I still can't crack throttle from idle to anything 1/2 or beyond. If I bring the bike off idle it's fair game. Oh well. I don't want to spend 300 dollars on a really nice genuine pumper carb like my hondas have. Final tune for now. Stock bike. Emissions removed and a Nibbi PEZ28 fitted. 38 idle jet Needle position 2 Air screw 1 1/2 Main jet 115. |
#19 |
Strictly a suggestion, you only need a screwdriver and some time - try turning the air screw IN a 1/4-turn (to richen the pilot circuit), ride the bike and see if the off-idle hesitation lessens. If so, try another 1/4-turn and test ride, until you think the hesitation is gone. If you get to being only a 1/2-turn from seated, then you might want to bump the pilot up to a #40.
Just my 2¢... |
#20 |
I started with the 40. It made me have to put the air screw almost 3 turns out to achieve highest idle.
The 38 puts me dead between 1 1/4 and 1 1/2. |
#21 | |
#23 |
Update. Still not right.
I think the 115 is too rich and causing issues. I'm going to go from 115 to 112. Which I'm pretty sure is going to throw everything else off. |
#24 |
Oof. Makes me glad I nixed the idea of putting in a new carb, this sounds quite frustrating.
2021 CSC TT250 |
#25 | |
The stock carbs should have had a 38 108 combo. The one I received had a 35 102 combo. After a few phone calls with CSC, it was determined that CSC could not get 38 jets for the Keima. So, they sent me the jet kit. The 40 idle jet didn't work but the 112 main did. The bike was very finicky. It really needed the correct idle jet. |
#26 |
New tune. Feels better ish. Need to have some real world experience over the next few days. It definitely accepts crack throttle better. Not perfect but better.
Air screw 2 1/2 turns out Idle jet 40 Needle position 3 Main jet 112 |
