Old 07-18-2024, 05:55 PM   #1
13313man   13313man is offline
Doh! 2008 gio atv 110cc
The rear axle bearings are shot , which bearings do I need or could someone stear me in the right direction to get a compleat rear axle.
I will include some pictures to take a look
Thanks
https://freeimage.host/i/dCQ4STu
https://freeimage.host/i/dCQ4kv9
https://freeimage.host/i/dCQ4eY7
https://freeimage.host/i/dCQ4vpe
https://freeimage.host/i/dCQ4Uhb
Old 08-05-2024, 06:28 PM   #2
PMac   PMac is offline
You can get the axle carrier with bearings off of Amazon, that's what I did. Also, when you fix it, make sure you tighten the axle nuts and get everything sitting dead center in the bearing or they'll wear out in no time.
It's a terrible design that I've been trying to come up with a solution for since I got one of these, but haven't figured out a solution yet. The axle is smaller than the inside bearing diameter, so it should have some sort of bushing in there, but I've been unable to find one that's the right size.
