Welcome. I'm sure someone will chime in.
welcome! give us some pic!
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
Welcome.
2022 Hawk DLX EFI * 17T Front / 47T Rear / upgraded chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
Welcome aboard! Most of us have been using this type of oil cooler. https://amzn.to/44qS2pD
Thank you for the info. I think the engine in the XF250 is different. My understanding is that it is a copy of an older Suzuki engine. the Hawk is a copy of a Honda. The adapter they supply for connection does not fit this engine. At least not that I'm aware of.
Welcome! There is an OEM oil cooler for this model, SSR decided not to equip the US models with it unfortunately. SSR does not offer it for sale . I've seen it on Taobao and debated buying it. The oil cooler equipped models require a different oil filter housing which is tapped for an oil cooler line fitting.
This engine is a clone of the Suzuki tu250x and also very similar to the Suzuki Ozark 250 and Quadrunner 250. If Suzuki made a cooler for any of those, I imagine it would be compatible.
2013 SSR XF-250 |
This looks like everything you would need minus the oil filter housing .
https://www.aliexpress.us/item/22558...2usa4itemAdapt
2013 SSR XF-250 |
oil cooler; xf250 |
