05-04-2024, 06:29 PM | #2 |
Welcome. I'm sure someone will chime in.
05-05-2024, 12:32 PM | #3 |
welcome! give us some pic!
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
05-06-2024, 08:58 AM | #4 |
Welcome.
2022 Hawk DLX EFI * 17T Front / 47T Rear / 428 x-ring chain * Kenda K-760 front + rear * Banjo brake light switch * LED headlight + front turn signals * Custom cutting board skid plate * Debadged (I don't like to brag about the superior strength!) * Top speed, GPS verified, as equipped: 68 mph (so far) |
05-06-2024, 09:15 AM | #5 |
Welcome aboard! Most of us have been using this type of oil cooler. https://amzn.to/44qS2pD
05-13-2024, 12:16 PM | #6 |
Thank you for the info. I think the engine in the XF250 is different. My understanding is that it is a copy of an older Suzuki engine. the Hawk is a copy of a Honda. The adapter they supply for connection does not fit this engine. At least not that I'm aware of.
05-23-2024, 09:24 AM | #7 |
Welcome! There is an OEM oil cooler for this model, SSR decided not to equip the US models with it unfortunately. SSR does not offer it for sale . I've seen it on Taobao and debated buying it. The oil cooler equipped models require a different oil filter housing which is tapped for an oil cooler line fitting.
This engine is a clone of the Suzuki tu250x and also very similar to the Suzuki Ozark 250 and Quadrunner 250. If Suzuki made a cooler for any of those, I imagine it would be compatible.
2013 SSR XF-250 |
05-23-2024, 09:35 AM | #8 |
This looks like everything you would need minus the oil filter housing .
https://www.aliexpress.us/item/22558...2usa4itemAdapt
2013 SSR XF-250 |
oil cooler; xf250 |
