New owner of an Ice Bear Fuerza - what is this?
![]() What is this lever on the left handle? It looks like a butterfly valve but I don't know what it is... |
Ha Ha!!
The teeny lever flashes your headlights, doesn't it? Is that the one you are asking about? It might flash the brights if the main toggle is on low beam. The slider is choke (forward to choke).
the on on the bottom is the turn signal switch. The one on top is to flash the bright lights.
Was asking about the slider. It's for a choke but disconnected as it's a different carb. Thanks!
