Old 11-15-2023, 05:06 PM   #16
Do©Hawk   Do©Hawk is offline
I friggin LOVE this thing. I can use it to commute saving huge on fuel and can "play" with it after work to decompress and sharpen my skills. Neighbors might not like it as much, but I'm not obnoxious with it.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 11-15-2023, 05:30 PM   #17
McQueen216   McQueen216 is offline
McQueen216's Avatar
This is the way.
SYM Wolf Classic 150 - SOLD
Triumph T100 SE
RE Scram411 - SOLD
Honda CB350
Honda CL450
Tyrion the Pit Bike
KTM 890 Adventure S
Old 04-18-2024, 12:08 PM   #18
Hi there! It sounds like you are already doing exactly what you need to learn. Just start wrenching! Nice work on the brakes.
Maybe you can check the valve clearance this Winter. Did the previous owner mention valve adjustment?
I just did a valve adjustment and oil change on Monday @ about 2000 miles. I think I might have adjusted a little loose on the valves. It starts and runs just fine, but seems a little bit more chattery than it was before. From what I've read, it seems a little loose is better than a little tight, but I'm probably going to take another swing at it soon.
2022 Hawk DLX EFI
strength!)
Old 04-18-2024, 01:25 PM   #19
cheesy   cheesy is offline
cheesy's Avatar
Tappy valves are happy valves.
Cheesy
07 Ural Gear Up
79 Honda CX500
77 VeloSolex 4600 V3
73 VeloSolex 3800
Old 04-18-2024, 07:53 PM   #20
That's what I've read. Does that mean tappier valves are happier valves? They've always been tappy, now just seems like a little more.
2022 Hawk DLX EFI
strength!)
Old 04-18-2024, 08:06 PM   #21
Too many different people hand out too many different valve specs. Often way too big.
My personal lash specs are .05mm intake and .07mm exhaust. You can also simply use the Zongshen valve lash spec of .07mm for both, with a check interval of 2500 miles. They will still be a bit clattery as that is just the nature of the beast with these engines, but it shouldn't sound like gnomes with hammers are on your top end opening the valves.
Old 04-19-2024, 07:19 AM   #22
Makes sense. I used .002" and .003"and while close, i think those are a hair bigger than .05mm and .07mm.
2022 Hawk DLX EFI
strength!)
Old 04-19-2024, 07:48 AM   #23
You are correct. .05mm is .001968 inches, so minutely smaller than .002. .07mm is .0027559 inches, also sightly smaller.
