Raven 250 Digital Cluster Question
I just got my 2023 Raven BSR 250 in and would like to put in a digital cluster. I found 2 on Amazon, but I don't know which one is the better option.
The first one is https://www.amazon.com/dp/B08P8YF75Y...BQ4FDF4HUK&psc and the other is https://www.amazon.com/dp/B0CLQH6Z3C...BQ4FDF4HUK&psc The only difference I can see is the more expensive one has the stock style speedo cable, while the cheaper has a magnetic sensor. If you could let me know which one I should get that would be greatly appreciated. |
#3 | |
Thanks for the reply. I'll just go with the first option. |
Installed the new cluster last week, and it's working well. It did require a lot of rewiring and figuring out what wire corresponds to what gear, since the wire colors don't match up.
