Old 03-21-2024, 07:33 PM   #1
Phane   Phane is offline
Resetting the ECU
Have anyone of you had to reset the ECU: this is the method described:
To reset motorcycle ecu, you can follow these steps:
Turn off the engine and the ignition switch, and unplug the ecu from your bike.
Remove the negative and positive wires from the battery terminal and leave it for 10-15 minutes.
Plug the ecu back to your bike, reconnect the battery wires, and turn on the ignition switch.
Start the engine and let it idle for a few minutes.
I was wondering would this cause any problems on my KPR 200
Old 03-21-2024, 11:15 PM   #2
krat   krat is online now
No more than replacing the old ECU unit with a new one!
Old 03-21-2024, 11:59 PM   #3
Turns out that all I needed to do was adjust my valve clearances and not bother the ecu or air gulp screw!
