Old 02-14-2024, 08:17 AM   #1
Purpose   Purpose is offline
First, thank you for the fast response. Not sure how to post pics here to show what is going on.
The first issue with the bike was a very small fuel leak that could not be found. Look to have be coming from a type of charcoal canister. This is assumed as there doesn't look like there are any damage to the fuel lines. When I pulled the line to reroute the vacuum lines, the lower line had fuel in it🤷🫣. Drained and took for a ride, and it eventually stalled again and had to let it sit for a minute before it would restart. It is breaking up under load, and then stalls.
Was going to try and pull the fuel pump and see if the fuel sock might be somehow contaminated. This all seemsed to start when I used 93oct gas, since the bike ran fine with the small fuel leak.
