How many of you KPX 250 OWNERS removed your back wheel if it was aready installed and greased the axle?
I didn't. I had to wipe of excess grease around the rear axle and front was well greased. But, it wouldn't hurt to check it.
That's how mine was too. I did grease the front one though, since I had to put the wheel on anyways.
NAW Showl didn't. I probably should though. I used to restore vintage Japanese bikes. And some of them took ALOT of persuasion and cursing to get the axle out.
