Old 12-25-2023, 06:21 PM   #1516
arielfall   arielfall is offline
New Templar X owner hear. Been looking around at modifications, anyone know if a PR300/ZS175FMN will drop in? I think it should compared to a PR250/ZS172FMM. Seems to be the same bottom end with just a bigger jug.
Old 12-25-2023, 07:02 PM   #1517
XLsior   XLsior is offline
XLsior's Avatar
I'd say your assumptions are correct and it would be a drop in swap.
Old 12-25-2023, 07:17 PM   #1518
That might be the thing to do, now they also make a 4 valve ZS175 with the same bottom end... Hmmmm.
Old 12-30-2023, 04:57 PM   #1519
Discoveror   Discoveror is offline
Question
Originally Posted by K'hermiit View Post
My 2023 Templar X has 13/49 gears and 50 mph has it screaming along @ ~8.5-9k RPM.
8,500 rpm at 50 mph vs. Mikd 6,000 rpm at 60 mph "with stock gearing" !!!
THAT's quite a difference; which is it?
Old 12-31-2023, 02:54 PM   #1520
K'hermiit   K'hermiit is offline
K'hermiit's Avatar
All I can say to that...is my numbers are pretty close. I was squinting over wind, but its close. I can check in a few days. Mine is down because of a stripped rimlock.
Old 12-31-2023, 03:33 PM   #1521
I hit 69mph at 9,000 rpm when mine was stock. I'm now at a 42 rear which hits 78 mph at about the same rpm.
Old 12-31-2023, 04:44 PM   #1522
It should go without saying that credible speed reports should be on relatively LEVEL ground with minimal wind, sitting straight up i.e. NO tuck! Of course, phone/GPS readings get extra credibility points!
Old 01-01-2024, 09:06 AM   #1523
K'hermiit's Avatar
I am curious now, I wonder if there is a speedo discrepancy? I will check it against a gps when I get the bike back together.
Old 01-01-2024, 11:36 AM   #1524
From what I've read (across forums), it seems that MOST motorcycle speedometers are 'optimistic' by 2 - 5 mph, compared to phone/GPS readings.
I get a chuckle every time I see a YouTube video, riding downhill (with a tailwind?) in a tuck, claiming that "Mine does x mph!". Maybe they were sliding downhill on horsepucky, too?
Old 01-01-2024, 07:04 PM   #1525
Greathouse   Greathouse is offline
Possible header option
Did some searching and came across this. Thoughts? It sure looks like it could be a bolt on cat delete header...
https://www.aliexpress.us/item/22518...mebLJrmC482Zt0
ID:	30599   Click image for larger version
Old 01-02-2024, 03:23 PM   #1526
vividpixel   vividpixel is offline
vividpixel's Avatar
I swapped the TX250 over to a Niche 110-link (removed 1) X-Ring chain this weekend and fit a new front sprocket: JT Sprockets JTF270.14 14T
Rolling around the garage there was slight friction, but a very short neighborhood test cruise took care of that. Perhaps luck of the draw that my particular engine had enough clearance.
Templar X 250: 14t / 42t, Nibbi PE30
Old 01-03-2024, 09:31 AM   #1527
Do©Hawk   Do©Hawk is online now
Not sure if its an issue on a non-EFI engine (can probably plug it), but that exhaust appears to have the bung for the oxygen sensor for fuel injection.
2022 Hawk DLX EFI
* 17T Front / 47T Rear / upgraded chain
* Kenda K-760 front + rear
* Banjo brake light switch
* Debadged (I don't like to brag about the superior
strength!)
* Top speed, GPS verified, as equipped: 68 mph (so far)
Old 01-03-2024, 10:26 AM   #1528
GypsyR   GypsyR is offline
GypsyR's Avatar
Borked my shifter up a bit. Borrowed a Suzuki shifter like our plastics are based on but the shift diameter was too big. Some talk about how similar our engines are to a CRF250 gave me the idea of trying one for those. Nope. Fits the splines but not enough offset to clear the engine case. Rerigged my shifter to keep on working and it's OK but still keeping an eye out for what may fit off a different brand. Just for the heck of it really.
Old 01-03-2024, 07:39 PM   #1529
Doubt it. Looks like the midpipe frame mounting boss to me. May or may not (likely) line up on the Templar. But could be managed.
Looks like a REAL candidate. and for $70! Yay
Old 01-03-2024, 09:07 PM   #1530
You're right. I don't know why I saw it the way I did the 1st time.
2022 Hawk DLX EFI
strength!)
