XF250 Carburetor Replacement
anyone know a good replacement carb for a SSR XF250X? either factory or aftermarket? mine is trash and probably easier replacing it. only thing marked on this carb is BZ29. Doesnt lead me anywhere thanks!
Please take a picture of what you have. I think it comes with a 26mm carb. Need to know how it is attached to the engine. Flange connection or spigot connection? An upgrade carb would be a Nibbi PE28 or PE28FL.
I have an 2022 SSR xf250 , the original carb was horrible, I put an nibbi 32 carburetor, then I also had to put a nibbi throttle cable also . The bike was starting alot better but cutting out terribly going up hills. So I just took off the side off air box and it was a totally different bike. Think next season I'm going try a new exhaust and hopefully it'll be even better. If that helps you out
i cleaned the old carb up today a little bit with a wire brush. found the number MV30P. made in japan. is it a real Keihin?
the tank on this bike was absolutely trashed. varnished gas, rust, water, just nasty. i was able to clean the original carb up. and it may be useable. seems the tank took the damage. |
