Raven 250 2023 Wiring Speedo ?
Anyone have the Raven 250 2023 Wiring Speedo ? Trying to install the
Zanella RPS Hawk Digital Speedometer, not much luck. Thanks in advance |
I installed this on a 2023 BSR Raven 250.
The individual wires are removed from the plug with the help of a small jeweler's type screwdriver. On the front connector just match up the colors except for the red/white wire, it needs to be joined with the blue/white wire. FRONT: red/white to blue/white At the rear connector once again match up the colors except for the light green/red stripe, it joins the green/red stripe wire from the wires you removed from the original plug to make the "N" light work. The blue/white wire joins the blue/white wire in the other plug at the battery position and the purple is unused. REAR: light green/red to green/red You will need to remove a small section of the mounting plate to allow for the wire harness (don't forget to paint your cut to prevent rust). Everything works just fine but at 60mph on the new speedometer, the GPS speed is 55mph. I haven't tried to adjust that yet, but I will in the future. |
#4 | |
My Zanella goes dark when I shift gears, doesn't matter which gear. Then going back to neutral the Zanella reboots, and all lights up, until the next gear shift.
Any thoughts / suggestions ? Thanks, I have a few hours invested in troubleshooting. |
250 raven, rpms, speedometer |
