10-21-2023, 11:20 AM | #1 |
Templar X best starting setup.
Hi guys. I have a 22 Templar X with 1200 miles on it. I was wondering, with an hot engine. Does any one else have to wind on the starter for about 3-4 revolutions before it starts up? I really like for a motorcycle engine to start on first touch of the starter. If at all possible. I’ve tried setting the air/fuel screw differently. But no change. Once it starts. It idles fine. It’s jetted 125/45 @ 500 ASL. Thanks guys!
22 Templar X 250 Hand Guards Custom Graphics Pro Taper Grips 125 main 45 pilot jets 42 tooth rear sprocket 2010 Yamaha Vstar 1100 Silver Star |
10-21-2023, 01:20 PM | #2 |
Hi Hap, maybe the valves need a look at. My bike is a ‘21 Hawk DLX and that’s what I’d do first, just my thoughts…
10-21-2023, 02:17 PM | #3 |
I opened up my valve gaps at 300 miles. They were tight. You can get starting difficulties from too tight of a valve gaps.
10-21-2023, 04:09 PM | #4 |
Yeah. Adjust the valves. And 45 pilot jet might be too rich. The pilot being a little on the rich side shouldn't prevent it from starting right away, just won't need choke!
I would guess valves, yes. Mine pops to life instantly. Yours should too. If it isn't better after adjusting the valves, I would be surprised!
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; 10-21-2023 at 09:42 PM. |
