Old 09-20-2023, 03:52 PM   #1
qtband   qtband is offline
Tao Axle Sprocket Help Needed
I need to adjust this axle sprocket to line it up. It looks like the hub is threaded. Do I just loosen the jam nuts and spin the hub on the axle?
Name:	110 sprocket.jpg
Old 09-26-2023, 11:56 PM   #2
danharris@1953   danharris@1953 is offline
on a taotao 125cc atv when installing new piston rings, does the black or silver ring go into the top groove on piston?
Old 09-27-2023, 04:28 AM   #3
Mudflap   Mudflap is offline
Silver ring goes on top.
Old 09-27-2023, 08:16 PM   #4
Head Scratching piston rings placement
The greatest of thanks for this info. Daniel.
Old 10-06-2023, 08:00 PM   #5
Could you please tell me what to torque the head bolts to on a taotao 110cc atv. Thanx in advance if you can, Dan.
Old 10-07-2023, 08:37 AM   #6
dirtbkr188's Avatar
... torque the head bolts to on a taotao 110cc atv.
9 ft.-lbs.
