Old 09-27-2023, 10:40 AM   #1
jake88ci   jake88ci is offline
xpro saipan 200 efi ridingat 50 mph bike stops
hello all have xpro saipan 200 (same as vitacci cash 200) Riding 50 mph with engine not overheating . bike just stops . getting fuel /getting spark but timing advanced ???
changed ecu , throttle position sensor , coil good bike has only 497 miles on it ? any help much appriciated
Old 09-27-2023, 11:15 AM   #2
Have you done a valve adjustment yet? Does it start after cooling off?
Old 09-27-2023, 05:07 PM   #3
clash 168cc   clash 168cc is offline
Use and monitor a fuel gauge to help diagnose when it shuts down. A bad O2 sensor or Temp sensor can shut down fuel. Try unplugging each one and see if the computer compensates to a predetermined scale like a fuel injected car would. I'm eventually going to buy another used Clash 200 so I will have extra parts.
Old 09-28-2023, 02:24 AM   #4
Hi jerry thanks for help . It has less than 500 miles and wont start at all .. Clash has fuel .thank you also
It definately has timing advanced .It has spark but there is no adjustment for timing? changed ecu and throttle position sensor ? This has professional mechanics puzzled lolol
Old 09-28-2023, 07:04 AM   #5
Mudflap   Mudflap is offline
Waiting for an answer to Jerry hawk's question about valve adjustment.
Old 09-29-2023, 12:21 AM   #6
hi mud flap no valve adjustment but only 497 miles on bike . and not acting like valve out of adjustment . it went from running great to engine stopping and not restarting in one fell swoop .
Old 09-29-2023, 05:09 AM   #7
An engine needs air, fuel, compression, spark at the right time. You say it has spark and fuel. Is the spark plug wet or dry. What is the color of the plug? Good plug like NGK or questionable brand like Torch? Air filter clogged or something blocking air flow? Will it run on starting fluid? My advice is to check the valves or check compression.
Old 09-29-2023, 07:52 AM   #8
If you never checked or adjusted the valves, that would be the first thing i would do. Most of these engines come with the valves set with little or no gap. Once the engine warms up the clearance goes away and valves don't fully seat. This will cause lost of compression and will make the engine hard to start or die until it cools off.
Old 09-29-2023, 08:20 AM   #9
Question .... if you install a new ecu on this bike do you have to do a ecu reset ? i knew i should not get efi gy6. should have stayed with traditional carb set up
Old 09-29-2023, 07:33 PM   #10
My valves had to be reset at under 1000 miles. They were very loose and started tapping. Never replace an ECU before checking all the basics first unless it's cheap and easy to get. I don't think this one is. If you have spark and possibly fuel do what Mudflap said.
Old 10-03-2023, 12:19 AM   #11
its only 68$ the entire throttle body is only 85$. ok Valve adjustment next
Old 10-03-2023, 07:29 AM   #12
It seems that .004" intake and .005" exhaust is commonly recommended for GY6 150 engines but I found that to be a bit loud. .06mm/.08mm (.00236"/.00315") is what is printed on one of the plates on the bike. That's what I use now and it's pretty quiet.
