09-09-2023, 03:01 AM | #10 |
Brace and Drill
Making the top brace mount:\
Cardboard assisted design... section of 2" box section... Many sparks later... Test fit and prepare to drill a hole through the van. M10 bolt and back washer... Solid... It's almost as if I spent many hours planning the swing rack or something... Need to trim the lamp housing to a little bit to clear the brace but should fit no issue.. Smooth out the rough edges and bedliner spray...eventually. Next is Jerrycan holders... |
