#1412 |
OK, I am lazy and short of time but this caught my eye. I see people here using Nibbi 28mm carbs on Templars. Then I caught a guy on Youtube putting a 30mm on and bragging on how well it worked. Very suspect credentials, OK none, on that guy but still. "On paper", a 30mm looks to be a better fit for 250cc that revs to 9K or whatever our redline is.
I feel pretty good good about my jetting of the stock carb but I keep seeing folks doing Nibbis and I am tempted. I'm very much not a fan of too large a carb though, I like "crisp" low speed throttle response and will take that over wide open performance. (OK, I'm getting old.) I know if I had a Hawk or some other 230cc it would be the smaller choice for sure. But opinions on 28 versus 30 on a Templar? |
#1413 |
Well I'm sure hoping the 30mm Nibbi works as that's what I have sitting I'm my garage waiting to be the first mod. Going to run and jet the stock carb first to get a baseline before trying the Nibbi. And I actually agree with you that low rpm throttle response is worth far more on these low powered bikes than an extra pony or two up top. Fingers crossed í ¾í´ž
#1414 |
Can't comment on the carb size other than if its too big it wont be running well.. the key is to get the best a/f ratio, bigger always is not better.. with that being said, if you want a performance gain without a doubt the de-cat of the stock pipe will be the best bang for the buck (free) paired with proper jetting of the stock or aftermarket carb
#1415 | |
22 Templar 250 |
#1416 |
My jet kit arrived at the house before the motorcycle did. So I was pretty aware of what it was going to need. (Thanks to you guys.) It's running pretty good but I think I can tweak it a bit more. Other than the horrific OEM bowl screws I've no problem with the stock carb.
As for a Nibbi being a waste of money... well, if I added up all the money I blew on stuff I thought looked fun/interesting to mess with I might get divorced. Guys on here talking about how you can buy an entire engine on eBay make me want to get one. For NO good reason at all. jc3, that wacky Mikuni ripoff looks pretty interesting. I would question if it were a direct bolt on like some Nibbis are though. But it's definitely cheap and I might have to study on that one. I also have an old Honda XL175 that I'm about sick of the carb on.... |
#1417 | |
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 06-16-2023 at 12:25 PM. |
#1418 |
Yeah, I showed that to a minibiking co-worker and he said "Oh yeah, a PWK. I have one and am wanting to upgrade it to a Nibbi. Wait, "Maikuni", what?"
#1419 |
Removing rear shock
Getting into replacing the rear shock now. Can the rear shock come out through the bottom at all? Or does it have to come out through the top? What all has to come apart to take it out? Thanks.
2022 Templar M 250 28 mm KIMISS carburetor 125 main 42 pilot Needle clip at center DID x-ring chain JTR897 45 tooth rear sprocket |
#1420 | |
The X has the ballonet (gas cartridge) that makes this necessary (M?). But you would have to remove all of the linkage below to pull it out from below (I am sure that is way more work).
#1421 | |
I went with an OE replacement shock. Tried to order a Templar X replacement from KKE but they were on back order.
#1422 |
Put my first few heat cycles on the Templar today. I set a baseline by running my Beta for an hour on my singletrack loop on my farm then running the Templar. This isn't to compare the two bikes as they are in very different classes but the little Tenplar handled everything in a relaxed manor that fits exactly what I was hoping for from it. It really does seem a nice simple little bike that punches far above it's price point.
#1424 | |
#1425 |
New Templar X owner
Hey guys, I've been following the thread since the beginning and have finally sold some stuff and am able to add something new to the stable. I just ordered a new Templar X and am super excited to receive it. Thank you all for the great info in this thread on this bike. I'm sure it will be useful when assembling and tuning the bike. Can't wait!
