Old 06-11-2023, 10:49 AM   #1
KenTaoyan   KenTaoyan is offline
KenTaoyan's Avatar
Metric bolt replacements
I was wondering where you all find/source bolts that rattle off on the happy trail.
I have a 150cc QIYI coolster quad that a couple of bolts went missing. One bolt in question on the head its printed ZT 8.8
Dr. Google was not much help. Where do you all find (or source/reference) bolt replacements?
~ toys in the cave (in the order of addition)
81 Honda XL185s {work in progress}
2018 QIYI Coolster 3150CXC 150cc Quad
2019 QIYI Coolster 125cc Quad
2021 Roughhouse 50 (neat little scooter for the wife)
2022 QIYI Coolster 3150DX-4
I may not be fast but I am "Half-Fast"
Old 06-11-2023, 11:48 AM   #2
zero_dgz   zero_dgz is offline
So, every single fastener I've removed from both of my Chinese bikes has been regular Metric coarse thread. Outside of possibly engine mounts, subframe bolts, footpeg mounts, and axles I don't think the hardness rating of the fasteners you use matters too much.
The "8.8" stamped on the head of your bolt means class 8.8 hardness. You can read more about hardness ratings here:
https://www.engineeringtoolbox.com/s...es-d_1428.html
Hardness determines some of the properties of the bolt including its shear strength, tensile strength, etc.
You can source bolts from any old place; the only requirement is that you get the right size and more importantly thread pitch. I prefer to use stainless hardware which you can either order from specialty bolt suppliers online or just get from the Usual Scumbags on Amazon. Flange head bolts are nice for anywhere that the bolt head will be exposed, because you can capture them on the end of your socket wrench and won't need a washer in most cases.
All of the common fasteners you will find on your bike should be one of these metric sizes:
M4x0.70
M5x0.80 (uncommon, although my RXB has a couple of bodywork screws in this size)
M6x1.0 (the majority of fasteners on the bike for sure)
M8x1.25
M10x1.50
Note that the bolt size describes the diameter of the threaded shank and its thread pitch and has nothing to do with the size of wrench used to remove the bolt.
Old 06-11-2023, 12:57 PM   #3
The handiest thing to keep in your tool box.
https://www.amazon.com/Thread-Checke...hoC9yQQAvD_BwE
Old 06-11-2023, 02:32 PM   #4
J4Fun   J4Fun is offline
Yep it sure helps with the guessing game…
Old 06-11-2023, 03:06 PM   #5
TominMO   TominMO is offline
My go-to is Ace Hardware for most bolt solutions.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 06-11-2023, 06:17 PM   #6
Bruces   Bruces is offline
There are little kits called “track packs “ ,full of common motorcycle hardware available online and I have a local power sports dealership that sells them ,handy to have and you can carry them with you on the bike ,with a descent assortment of stuff ,and the quality of the ones I can get locally is pretty good .
Old 06-12-2023, 10:06 AM   #7
KenTaoyan's Avatar
What it ended up being was M12-1.00 x 30MM
I found something at Autozone that is stronger but longer so I needed to add a few washers.
Life is but a learning experience......
Old 06-12-2023, 03:08 PM   #8
M12 threads? That's a chunky bolt for a small motor
Old 06-13-2023, 01:13 PM   #9
KenTaoyan's Avatar
Quad rear axle support. Two bolts rattled off and the chain jumped ship. Easy enough fix but locating the same bolts proved the most challenging. I was temped to drill out the welded nuts and just throw some grade 8 bolts and nuts in.
All is good, thanks for all the help. I am never disappointed on the support from this group.
Old 06-13-2023, 08:35 PM   #10
Oldenslow   Oldenslow is offline
In my dinky little SC town, in the small family-owned century-old hardware store, I have found every metric bolt or nut I have needed on my Chinese and Japanese bikes.
bolts, metric
