Old 05-21-2023, 08:33 PM   #1
BakedOregonian   BakedOregonian is offline
2022 Hawk question
If I have the front wheel firmly between my legs, how much play should there be (left to right) with the handlebars? And if there's too much, how would you fix it?
Old 05-22-2023, 10:29 AM   #2
Sport Rider's Avatar
there should not be play. double check your axle setup and bearings.
Old 05-22-2023, 10:52 AM   #3
Depends on the play. A video showing it would be a huge help.
Old 05-22-2023, 11:32 AM   #4
I did a similar test before I put a fork brace on, and they do have some springy feeling twist, but mine didn't really have play, as in slop in it.
Old 05-22-2023, 12:32 PM   #5
J4Fun   J4Fun is offline
I agree with all the above! A thought start from the top and work your way down making sure all the bolts are tight. Handle bars then fork clamps then axle nut tighten to spec. If any unusual slop think steering neck bearings and grab the handle bars by the tube not the grips. The throttle might throw you off because it will have some slop. My thoughts…
