Old 05-01-2023, 12:35 AM   #1
98 SNAKE EATER   98 SNAKE EATER is offline
Question Weird issue with LED lighting......
Rewiring my Cyclewerks Heist project bike using all EBay/Amazon LED's
Picked up a cheap turn signal/headlight master switch as well as a new all in one speedometer that has both left and right turn signal indicators.
The front marker lights are 3 wire (Ground/Turn Signal/Running)
The rear marker lights are 4 wire (Ground/Turn Signal/Running/Brake)
Using an adjustable LED type flasher unit
Wired it up and the signals all work as they should, however, the running lights won't turn on when I connect the ground for the speedometer
The running lights work fine when the ground for the speedo isn't connected
I have yet to install any diodes, but on other bikes I've wired, the diodes only helped when the turn signals didn't work
Are they also required for just running lights?
