Old 01-20-2023, 09:20 PM   #1
fishaholic   fishaholic is offline
KPX front brake wire connection
Does it matter which prongs on the switch the wires hook to? There is a black wire and what appears to be a green/white stripe. The 2 prongs look to be the same size.
____________________________________________
2022 kpx250
2007 Suzuki dr650se(project bike)
2002 Hyosung prima 50
1979 Kawasaki KZ650sr
1972 Kawasaki F7 175
1971 Kawasaki G5 100
Old 01-20-2023, 09:43 PM   #2
TominMO   TominMO is offline
Is there any lettering or symbols to indicate which goes to which? I think black would be ground. It may not matter though. It just wants to see current when you make the connection by pulling the lever.
Jerry: Any chance you can get a wiring diagram from Venom?
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 01-21-2023, 03:24 AM   #3
It doesn't matter. The brake switch only completes the circuit.
Old 01-21-2023, 06:20 PM   #4
Ok thanks guys, I hooked the wires up no particular way and it works. It makes sense that when engaged all it does is make the connection between the two wires. So the bike is together with no problems, started as soon as I touched the starter button and everything seems to be adjusted perfect as far as the clutch and brake lever play. The chain has 1 inch of movement in it. So far its very impressive! Hopefully the shocks will settle in after a few hundred miles, I'm 5'10 and barely stand flat footed while sitting on it.
2022 kpx250
Old 01-21-2023, 06:33 PM   #5
I'm 5'10" as well. The rear shock will settle in. I can now flat foot the KPX. I got into the habit of mounting the bike like a horse. While it's on the kickstand I put my left foot on the peg and swing the right leg over the seat. Ain't as young as I use to be. Lol
Old 01-21-2023, 07:35 PM   #6
Thats the way I have to mount it too(almost 65 years old). Just have to make sure its on firm ground.
2022 kpx250
