Disable Front Brake Requirement to Start - Templar Pro X 250
Anyone know if it's possible to disable the "feature" requiring the front brake to be held/engaged in order to start the Templar Pro X 250s?
I am fighting some starting issues and it's getting really annoying remembering the whole sequence of finger choke, front brake, push button (and try to twist throttle while still holding brake). Also, can these be push started with this front brake "feature"? |
Its just a switch. Either the two wires are connected or disconnected.
The switch is in the circuit for the electric starter motor and not in the circuit for the spark plug energization.
The problem with bypassing the brake interconnect is the loss of a functional brake light. I too hate this safety "feature" but need a working brake light. If you ride strictly off road and don't care about a brake light, just cut the two wires and connect them.
If it helps, you can also use the rear brake to start the bike.
22 Templar 250 |
Try looking at the other end of the circuit. If the electric starter motor circuit activates when voltage is applied across either brake control to brake light circuit then you just need to find where it feeds off to sensor, or relay and cut that out of the brake circuit and feed a constant voltage to it from the key turned on circuit.
#6 | |
#7 | |
Thanks for the insights. Now back to figuring out why the hell this thing with 4 miles on it won’t start anymore. |
My Templar M did that, with about 5 miles on it. They ended up sending me a new carb.
Templar M 250 TaoTao 140 Daring Greatly |
#9 | |
Good luck.
22 Templar 250 |
#10 | |
It comes with the following: 1 x Slow Jet Available Size #40 3 x Power Jet Available Size: #120 122 125 I'm at 1400' - Was thinking about starting with the #120 and #40... |
#11 | |
22 Templar 250 |
The absolute craziest thing happened. I have a '22 X-Pro Templar 250 and I went out to adjust the handle bars. I loosened the hex bolts, pushed the bars forward a couple of inches, centered the bars and tightened the hex bolts back down. Here's the crazy part. NOW I can start the bike by just pulling in the front brake. I shit you not. I have no explanation whatsoever as to why or how this changed but now, I turn the key on and just pull in the front brake and it works just like a starter. I don't have to pull the clutch or anything. I just make sure it's in neutral. I was actually going to research the wiring after adjusting the handlebars to see how to disable the "hold the front brake while starting" issue. It's been about a week now and I kept waiting for it to go back to normal but it has remained the same. During operation the front brake works like it should. I'm not gonna research it anymore cuz I don't wanna look a gift hoarse in the mouth if you know what I mean.
#13 | |
CHECK to make sure that your STARTER button isn't stuck IN. Wiggle it out. Make sure it isn't stuck ON while riding. It will drain the battery and destroy your starter. It happened with my 6 speed. The starter button can get sidewys, stuck. That explains it.
#14 |
There was a post in the Templar X 250 thread from IA_gravel runner on how to defeat the brake lever pull to start requirement. I think it makes it a clutch pull start requirement, but he will have to explain. If true, it is easier than a brake lever pull while pressing the button and controlling throttle!
https://www.chinariders.net/showpost...postcount=1305
#15 |
To clarify something for lurkers and future Templar owners, there is no requirement to pull the front brake specifically; either brake works. It's still undesirable behavior but holding the rear brake also allows the Templar to start.
Templar X 250: 14t / 42t, Nibbi PE30 |
