12-08-2022, 06:52 PM | #1 |
Brozz Steering Bearings
So awhile back my son told me that the steering was feeling stiff.. i loosened up the steering nut a bit but found that there was what looked to be a rubber gasket sticking out under the neck and i could see some ball bearings when i loosened up a bit further. I want to completely remove the steering head and re-assemble with some new bearings and whatever gaskets may be chewed up and pack with grease.. I found this thread and confirmed thru Jeff that it uses loose ball bearings. Now on my Templar X when i put the steering together it had a sealed bearing pack, does anyone know if the same can be installed on the Brozz?
Link to older thread: https://www.chinariders.net/showthre...ht=triple+tree Jeff said it should be similar to this but want to confirm what my options are so that i can order ahead of time and not have it out of commission for long: https://cscmotorcycles.com/zt20-101-...2016-up-tt250/ thanks
2024 Templar 250 2021 Beta 500 RRS 2018 VStrom 1000 XT Former China Bikes: Tao DBX1, Brozz 250, CSC RX4, Titan DLX, Templar X, Storm DLX 150 |
