Old 11-27-2022, 07:48 AM   #61
TominMO   TominMO is offline
Wow, cool use of PB. WD40 is also good at this.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Old 11-27-2022, 10:47 AM   #62
Hap   Hap is offline
Thumbs Up
End of day. I let the sticker residue soak for hours while I went about my day. Peanut butter is 100% plastic safe and 100% will remove sticker goo.
Now the only issue is the thread they used to sew on the velcro, if it is cotton or whatever it is, it broke when undoing the velcro being stuck to iteself. I need to glue on the broken off velcro bits and then this cover is done.
Nice and clean, goo free.... but now I feel like a snack!
Attachment 27935
I hope that peanut butter trick isn’t brand specific. Jif is my favorite! (:
Old 11-27-2022, 05:28 PM   #63
Brand of peanut butter is not important for the goo removal process.
I wish it was JIF, but it is Skippy. Costco had recalled all the JIF when they had the salmonella contamination and they replaced all the JIF in my local Costco stores with Skippy.
Old 11-27-2022, 05:32 PM   #64
Templar x 250 is done
Well,
The time has finally come. I ran out of things to do before inspection and registration.
I still have plenty I want to do to the bike after inspection and registration: Suspension work, Rim Lock delete, Wheel balancing, Gearing changes, etc.
Sticker peel is done. The right hand side panel had a lot of trapped air bubbles as compared to most of the other panels on the bike. I pricked them with a small needle and got most of them squeezed towards and out of the single hole.
Name:  Build Finished 01.jpg
Rear profile trying to tempt me to ride as its one of the warmer days we'll have this week before the next canadian cold front hits.
Name:  Build Finished 02.jpg
Front profile.
Name:  Build Finished 03.jpg
Ignore the charger/tender, detail of the rear fender sticker.
Name:  Build Finished 04.jpg
Old 11-27-2022, 09:11 PM   #65
Hap   Hap is offline
Looks good!
Old 11-28-2022, 05:40 PM   #66
Just bought the insurance, that means I am free starting tomorrow to ride it to a shop that does state vehicle inspections and get the safety inspection done that is required by the county to register it.
Old 11-29-2022, 12:27 PM   #67
First ride what a blast
First Ride
10 Miles put on the OD.
I got lost in my own housing estate! - LOL
I never visited the back half of my housing estate before as it has only recently been constructed and houses built out, so I rode back there to have a look. Went through half the streets up and down as I got familiar with the bike handling at low speeds.
As the engine was now getting its own scoop air cooling I did some minor adjustments to the idle screw halfway through the ride and dialed it in nice.
Then I went out to the street on that side of the estate and headed north thinking I would hit the farm to market street that runs west to east on the north side of the housing estate.
There was some construction, I slowed down for that, passed on by and kept riding into the dappled shade of old tree lined curvy rural roads. What a lovely ride.
And then I noticed I never hit that farm to market road and instead ended up 4 miles up the road north past it some how.
So the adventure is already beginning, seeing more to the world around me that I never did before.
Wows from the ride. 24 MPH in 5th gear and 35 MPH in 6th gear. I will definitely need to install that lower tooth rear sprocket I have sitting on the workbench table.
I wound it out a bit on the ride back when I hit the wide straight housing estate development roads and got off the rural road section. I must have gotten close to 55 MPH indicated on the digital dash.
But yeah, it was pushing it to get up there on an engine that still needs the break in process with OEM low gearing.
Old 11-29-2022, 05:51 PM   #68
Hap   Hap is offline
First Ride
And so it begins! You will know every nook and cranny in the country before long! I’ve got a whopping 11 miles on my bike so far. I hit 55 the other day pretty quick. But I’ve got to pickup a 42 tooth rear sprocket for sure. The first nice free day I have. I’m going on a good long ride! I lack the left side shroud finishing up my graphics install. That turned out to be a pretty time consuming project. But I think it’s going to look good. Glad everything is coming together for you TP!
Old 11-29-2022, 11:33 PM   #69
I did more work but now that its build is finished and inspection time, I moved those posts to the main Templar X 250 thread on the forum.
I have my chain now, I have my sprocket. I just need a chain breaker tool to continue.
I also am not as motivated to jump right in before inspection because I also have my tire spoons, rim guard and more importantly rim lock caps so I can finally pull the tires, pull the rim locks out, rinstall the tires and balance the wheels with wheel weights so the are ready for higher speeds.
Then I have to pull the rear wheel sprocket, install my new sprocket, reinstall the rear wheel, install the new chain, set the chain slack... yeah too much before inspection, I'll do that after inspection is done and/or after going in for registration with the county.
Old 12-01-2022, 08:49 PM   #70
Fast_Freddy   Fast_Freddy is online now
Fast_Freddy's Avatar
I ordered a new Templar 250 from PSM on 11/26/22 and as of 12/01 it hasn't shipped. :(
Old 12-01-2022, 09:54 PM   #71
Hap   Hap is offline
Wow! That is odd. Have you received any emails from Powersportsmax or Maxpro regarding your order since you paid?
Old 12-02-2022, 12:51 PM   #72
They updated my status late last night to show that they shipped my bike yesterday. Estimated delivery date 12/07. I also received emails from Maxpro.
22 Templar 250
Old 12-02-2022, 12:56 PM   #73
Not ruling out coincidence, but they do monitor these threads, just sayin
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 08-17-2023, 05:34 PM   #74
Mike3456   Mike3456 is offline
How long did it take to get your motorcycle from powersportsmax?
I live in Illinois or just a little over 2000 miles away from powersportsmax. I ordered a 125cc cafe cruiser yesterday and the current status is verifying billing. I was hoping to get it by next friday while im on vacation. But if it comes after my vacation can it be delivered in the afternoon after work?
Old 03-11-2024, 03:11 PM   #75
nakroyr   nakroyr is offline
Has anyone had a recent experience with shipping large or specialty items? What company did you use and how did it go?
