#166 | |
#167 |
Well, that would explain the disconnected lead under the tank; if I ground it out, the 6th gear pops up on the display.. That's some good info though! I'm still piddling with the gearing on my Titan DLX but, 70MPH is surprising. Man, I want 6 gears so bad lol just ONE more gear, and it would be almost perfect. Hell of a lot more comfortable I bet, that's for sure!
I'm going to definitely get the 14T gear BUT... there are two different ones that are possibly a match, three really. I need to measure the spline again just to really know - but, the JTF328 is a match, I've been using the JTF1329, and I just saw the JTF1554 might be a fit too. The stock 13T does have a little lip on the engine side, and is pretty beefy. The 1554 seemed more like the stock dimensions to me - no complaints from the 1329, but only 12T and 13T. I found out 12T is max for an O or X ring chain, but it wears a little on the sprocket walls.. kinda thick. So, I'm running Niche standard chains from now on. My current gearing is 13T stock front / 40T rear @ 70MPHish. Ish because downhill I can hit 76MPH lol but a good gust of wind is needed as well. But have hit 76MPH via GPS WOT / 70MPH comfortably (minus the vibrations). The 14T front will hopefully provide a few more MPH? Hopefully.. Getting this thing up to 55MPH+ isn't hard, but good lord - it turns into a vibrator on wheels!! ![]() ![]() Keeping that 6 gear model in my mind for sure - might be a future purchase!
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
#168 |
This is the 14T I have on mine but you will need to shave down the inside of the sprocket cover.. see my previous post on that with pics:
JT Sprockets JTF328.14 14T Steel... https://www.amazon.com/dp/B001AVOMOI...p_mob_ap_share
#169 |
The nice thing about the Templar as well is that it has a carb for those that want to be able to get more performance out of the bike without headache of if/how to flash an ecu
#170 |
Well, it arrived about noon today. 2 issues, the front fender looked like someone took a hacksaw to it and the SOI had dirt bike instead of motorcycle. Called them up and figured out the process for parts replacement and they said a new SOI will be sent. removed front wheel and tightened spokes/aligned wheel. lubed the bearings and removed triple trees to tap a zerk in the steering head. A good day. Edit to add . What's the fork oil capacity?
#171 |
I drilled and tapped the steering head for lubrication of steering bearings. R+R fork oil ,adjusted the valves, blocked/removed EGR junk. Installed new CDI and oiled the filter. Getting ready to install the front wheel. All pretty good so far.
#172 | |
![]() Does that orange box add-on or replace existing CDI ?? I am wondering if it is an alternative to advance key for a slight advance. I wonder how many degrees it really advanced the spark? Electronic advance is a a common superbike mod, like Dynojet Power commander, which has maybe five advance curves to choose from. |
#173 | |
I cleaned up the oil and found NO OIL source opened on the bike ![]() And, the middle lower section under the bike was crushed as if dropped! This did NOT come like this from the warehouse! I bought from PSM. They sent me a right foot pegs, though I didn't really need it. PSM was good. Fortunately, the bikes are pretty tough ![]() Last edited by Thumper; 08-23-2022 at 02:34 PM. |
#174 | |
#175 |
A question for the collective. My rear shock has a charge valve for nitrogen, what is the proper pressure for the shock?
#176 |
hey gang, just snagged a 2020 Titan DLX yesterday in fair condition for $700! Unfortunately it did not run but will fire with starting fluid. The carb is toast. I ordered a VM26 clone linked in this thread from Amazon, but I'm seeing other posts on Facebook about Nibbi carbs. What is the best carb out there right now to go with? I am hoping to run a less restrictive air filter and may get a big bore kit if I can find one for a reasonable price!
#177 | |
#178 | |
A little bit premature but I'm also looking into Henner's kits for more power, though I haven't even ridden the thing yet. |
#179 |
Can anyone confirm that the CRF230 big bore kits and camshafts will or won't work on the Titan DLX (223cc?)? I can't find any confirmation. Hoping maybe Plump or Obrien can chime in
#180 | |
