Old 07-20-2022, 09:48 PM   #1
dazoed   dazoed is offline
Oh No 2022 Boom Vader bd125-10 clutch trouble
I received my BD125-10, assembled, drained out dirty oil, filled and drained oil again to clean out any junk, which there was a little. Filled with wet clutch 10w-40 motorcycle oil.
At first the clutch was meh, when shifting to first it would lurch a bit but wouldn't take off. after a few short rides it was harder and harder to shift. 2 miles total. Now it acts like there's no clutch at all. Shifting into first and the bike will either take off or just die. The cable is adjusted ok, when pulling the lever the clutch arm on the right side of the engine moves fully.
Anyone have any suggestions or know of any known issues with the clutch on these bikes?
I think I solved the problem.
Adjusted clutch behind cover, via
http://www.chinariders.net/showpost....0&postcount=14
I think the lock nut was loose and it was slowly backing out.
The bike still lurches forward though,
Old 07-22-2022, 07:56 AM   #2
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Just double check your adjustment at the 3 adjustment points on the stock cable.
These things shift like crap out the box.
I had to tighten my clutch lock nut and make the adjustment at the handle bars to get my clutch right. My original stock cable snapped so I installed a new one, hit the adjuster at the lever, tightened the clutch lock nut, I've been doing good ever since.
You have to get some more miles on it to get rid of some of the crunchiness but if that doesn't do it then go further in the clutch and investigate your star shifter rod
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 07-23-2022, 05:22 AM   #3
Big Bird   Big Bird is offline
Big Bird's Avatar
You can't adjust these bikes like is typical with freeplay in the clutch lever. It has such a long range. Tighten the cable until it doesn't buck going into gear. Adjust is based on the springs in the clutch not the spring on the clutch arm. Change the oil often for the first 500 miles till the gears wear in.
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
