Old 07-22-2022, 03:16 PM   #1
putterputter   putterputter is offline
Brozz Rear Tire replacement
I have a Brozz 2020 (NOT the RECON)with the stock tires and I am looking to replace just the back tire for now as the front is still in good shape. I wanted to see what you guys thought would be a good replacement and close match to the stock tire.
I think the Shinko Dual Sport 705 Series Front/Rear Tire (120/90-17TT) Manufacturer Part Number ‎87-4520 is close to the stock tire tread pattern,
I believe this to be the size:
Rear 2.5x17 wheel with 110/90-17 tire
Old 07-22-2022, 06:24 PM   #2
severely   severely is offline
My advice is to look at the tire to swingarm and brake stay arm if equipped. And make absolutely sure of clearance as the Shinko is probably 1/2' wider at least. Your choice of the 705 pattern is a good one, I've put over 50k miles on these without issue. Good luck, happy trails. Edit to add, I think you'll find the rear wheel to be 2.15x17, please correct me if I'm wrong.
Old 07-22-2022, 06:47 PM   #3
THe 120/90 Shinko 705 will clear everything just fine and will mount to a 2.15 width rim without issue.
Old 07-22-2022, 07:54 PM   #4
Back rim is stamped 17 x 2.5 DOT
Old 07-22-2022, 11:19 PM   #5
Yeah, you will be fine with a 120 tire width. Heck, you could run a 130/90-17 on a 2.5 rim width if you really desired to.
