Old 06-07-2022, 06:52 AM   #1
Leonard   Leonard is offline
Tao 110 Replaced Starter but still hardly turns over
I replaced the starter because it was barely turning the engine over. I had to hit the starter button several times ...click...click...click...then barely turns over.
I'm lost on this one...any suggestions??
Old 06-07-2022, 06:53 AM   #2
after I replaced the starter it was the same click, click, click...then straining to barely turn over...
Leonard
Old 06-07-2022, 08:10 AM   #3
dirtbkr188's Avatar
Sounds like you need a new battery
Old 06-07-2022, 09:19 AM   #4
Boatguy   Boatguy is offline
Boatguy's Avatar
Check on the connections and clean them. Then check the battery.
2020 Lifan x-pect
Old 06-09-2022, 07:14 AM   #5
well, it's a new battery and I also put it on a 225A charger/starter resulting in no change...it just barely turns over after several tries...severe straining.
Old 06-09-2022, 07:56 AM   #6
dirtbkr188's Avatar
I would try squirting some WD-40 into the spark plug hole and see if it turns over any faster.
Any prior issues with the engine? Has it been run before on a regular basis without any problems?
Old 06-11-2022, 05:10 PM   #7
Try starting it with spark plug out. Also, try bypassing the starter relay by jumping it straight to the starter.
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
