Has anyone actually gone 17t sprocket on the magician?
Has anyone actually done is 17 tooth sprocket on the magician because I just tried to put my new chain on and there's no way it fits I don't know what to talk about grinding stuff to make it fit cuz it's the timing case and you have an electrical there too
Can anyone do the math for me to have same gearing as a 17t but change the rear. Stock 45 t i believe for the rear |
I have a 17t on the front of my Magician. I didnt do any grinding or anything to the front cover. I did buy a longer chain. The type I used was a T428H. The keeper is installed in the normal position.
#4 | |
2018 Bashan Storm(sold) 2016 Magician 250 |
Mmm. Maybe some Magicians are different. Mine is a 21. You definitely cant use an O-ring or super heavy duty chain but a roller fits fine. I helped someone else a few days ago too and it worked for them. Check my old post I had the part.# for the chain I used.
Mines a 21 too...hows u guys get it to fit. Theres nothinf to grind since there electrical right there too
Mine fit fine. The cover goes on well too. I'm thinking maybe your chain is too heavy duty, or an o-ring chain. I have about 500 miles with this setup with no issues.
Does your stock chain fit around the sprocket? I know it's too short but the size is the same as the aftermarket one I bought.
: Originally Posted by CGcloner229 View Post Has anyone actually done is 17 tooth sprocket on the magician because I just tried to put my new chain on and there's no way it fits I don't know what to talk about grinding stuff to make it fit cuz it's the timing case and you have an electrical there too Can anyone do the math for me to have same gearing as a 17t but change the rear. Stock 45 t i believe for the rear I couldn't get a 17 on mine either. I ended up putting a 16t on. It gets up to 62 to 63 on gps. Really cuz theres a gaurd by front sparket tht faurds the ekectrical rig ht behind it. Like no way it fits bro..guess ima have to drop to a 4ot for same gearing with the 15 tooth. Is there any effect changing rear sprocket vs front? I just do t see it unlrss theres a magic trick im miss |
The problem with changing the rear sprocket on a magician is that the bolts are too close too the chain. It can be done but the sprocket is very difficult to find and sometimes had to be made special. Are you sure you have a 428 front sprocket and not a 530?
Ya no its a stock 428h or w.e.. i might jus have to try the 16. So weird some ppl saying it fits....lotz of discrepancy, diffrent models/ years
#12 | |
Basically, once you get the cover on it functions fine. The issue is when trying to install or remove the sprocket cover the chain interferes with the inner portion of the cover and binds up against the chain a little bit. This is just because the cover has to tilt back some to be removed. If it installed straight on and off this would never be a problem.
