Old 05-17-2022, 10:48 AM   #181
Joe Schutts   Joe Schutts is offline
Link for stock air filter replacement???
Hi Jerry,
By any chance do you happen to have a link for a air filter replacement that will attach to a stock X22R carb???
Also I just got in a new EGR (at least I think that's what it's called) Universal Block Off Plate but I am unsure about which tubes to disconnect and which ones to leave attached. Do you (by any chance) happen to have (or know of) a Youtube video that shows which tube to disconnect and which ones to leave attached???
Thanks for your help...
Take care and ride safe...
Joe...
Old 05-17-2022, 10:59 AM   #182
Originally Posted by Joe Schutts View Post
[FONT=VerdanaHi Jerry,[/FONT]
Joe...
I don't have a link to the air filter as I removed the stock air box and installed a pod filter.
Remove all the hoses and plug the brass nipple on the intake manifold.
Old 05-18-2022, 08:06 AM   #183
Pod Filter???
Hi Jerry,
I should have asked for a Pod Filter suggestion instead of an air filter replacement. Sorry about that. Do you happen to have a link for a recommended Pod filter that will fit unto a STOCK carb???
It's finally gotten warm enough to start riding again. Thank God... Now to just get the mods done...
Joe...
Old 05-18-2022, 08:13 AM   #184
Hi Jerry,
Joe...
Any 42mm 2 stage foam pod filter will work. https://www.amazon.com/LIYYDS-Univer...e%2C97&sr=1-51
Old 05-18-2022, 03:35 PM   #185
Air Pod Filter...
Thanks...
See ya...
Old 05-18-2022, 03:53 PM   #186
Removing the Air Box???
Hi Jerry,
You said that you removed the Air box???
Doesn't the air box (at least the upper part) make up the base (or the floor) for where the tool pouch sits???
I don't want to remove the air box and then find out that my tool pouch fell out of the compartment because there was no flooring.
Old 05-18-2022, 03:57 PM   #187
The tool compartment is separate from the Air Box.
