advance timing
I have a shipping problem buying a flywheel key 4dg..
so what about move the pick up?? i i want to have 4dg of advance .. how many mm have to move the pickup?? |
Determine the circumference at the sensor
All you need is the radius circumference is 2(pi)r Then multiply the circumference time 4/360: circumference x (4/360) So, if the distance from the center of the axel to the pick up is 40mm (radius), 2x pi x 40 = 251 251 x 4/360 = 2.8mm |
