02-03-2022, 11:23 AM | #1 |
Zanella Digital Speedometer
I recently purchased a Zanella cluster from Amazon. Mostly because I wanted a tach, but I also hoped the speedo would be more accurate than the mechanical unit. It wasn't. My hawk has a 21" wheel and speedo was set at 21 but after resetting to 19" it was perfect. this unit also has a 17" setting that may be helpful to TBR7 owners.
02-03-2022, 11:26 AM | #2 |
I had set mine to 19" as well to make it accurate. I have the original Digital speedometer that Matt, one of our members was importing and selling on the forum.
02-04-2022, 10:46 AM | #3 |
I have not seen any documentation on how to set the wheel size when I did my Zanella upgrade. can you please send or point me to it?
thank you
~ toys in the cave (in the order of addition) 81 Honda XL185s {work in progress} 2018 QIYI Coolster 3150CXC 150cc Quad 2019 QIYI Coolster 125cc Quad 2021 Roughhouse 50 (neat little scooter for the wife) 2022 QIYI Coolster 3150DX-4 I may not be fast but I am "Half-Fast" |
02-04-2022, 12:26 PM | #4 |
To accommodate a 17" or 19" tire.
To switch to a different tire size complete the following steps: While in the off position, press and hold the button on the speedometer. While continuing to hold the button, turn the ignition to the on position. Then, select the desired tire size calibration. |
