Old 10-11-2021, 01:33 PM   #1
Aufgeblassen   Aufgeblassen is offline
How Much Oil Does The Tao Motor TBR7 Actuall Take???
I be confused!!! I went to change my TBR7 from factory "shipping oil" (whatever that is), and supposedly (according to Manual) one is to add 1.1L or or 1.16 quarts or 37 ounces.
I drained the factory oil (w/o spilling a drop), which read had to top line of dipstick and then put it into Slurpee type cup, and then put it into empty oil bottle after adding, but it only read 800 mL or only about 27 ounces on bottle!
I watch a YouTube of someone changing their oil in same exact bike, and they are adding only seven (7) ounces of oil! - WTF?
Do I need to add 7, 27, or 37 ounces of oil during a routine change??? - thanks!
My idea was to add slightly less than nominal (1 quart vs. 1.1L), as I will be changing oil AGAIN at 600 miles to synthetic oil, and did not want to buy 2 quarts for only 5 ounces more.
Old 10-11-2021, 02:19 PM   #2
cycleway4   cycleway4 is offline
I think you will find everyone on here goes with 1 quart at change. I have always used just 1 quart (Brozz250) works out great. Also,..to note,...I use Shell Rotella T4 15w-40
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 10-11-2021, 02:38 PM   #3
Thanks! I did use that from brand new, but at 600 miles, I will definitely switch to either full synthetic Shell Rotella full synthetic oil, Delvac 1 full synthetic oil, or Chevron Delo full synthetic oil (whichever is cheapest in 1 quart bottle at Walmart.
Old 10-11-2021, 02:42 PM   #4
braindead0   braindead0 is offline
Enough... add enough to get into the 'good' zone on the dipstick.. measure as you are adding and write that down somewhere. I think that inconsistency is the only constant for most of these bikes, trying to compare one to another may not be useful.
Old 10-11-2021, 03:13 PM   #5
When I added 1 quart, it read OVER the dipstick top line slightly, even though it was seven (7) ounces less than the 1.1L capacity. I'n not worried about an "overfill".
I assume you read dipstick when it is screwed fully IN and not just sitting on top not screwed in, right?
Old 10-11-2021, 03:59 PM   #6
Well, that depends. I've seen some that call for screwing in completely, some not.. honestly I'm not even sure which is more common! Seems to be going for a bit overfull vs. underfull would be preferable.
Old 10-11-2021, 07:22 PM   #7
david3921   david3921 is online now
I always go by NOT screwed in, sitting on the bike, and holding it perpendicular to the ground the best I can. Don't these have a sight glass also?
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 10-11-2021, 07:30 PM   #8
Nope.
Old 10-13-2021, 01:21 PM   #9
Drain it. Dump in a quart of your preferred lube, ride.
Old 10-13-2021, 01:59 PM   #10
Do you level bike (i.e. off kickstand) to drain every drop of old oil. or is it not necessary?
Old 10-13-2021, 02:01 PM   #11
You'll never get every drop out. I usually rock bikes to make sure I get rid of most of the oil that's in the bottom of the case.
Old 10-13-2021, 02:21 PM   #12
buzz   buzz is offline
1 quart
Old 10-13-2021, 02:39 PM   #13
1 quart Rotella 15w40
2024 Zuma Storm 150 DLX
2019 Beta 430 RRS
Old 10-13-2021, 04:01 PM   #14
I will make sure it is FULL synthetic at 600 mile oil change.
Old 10-28-2021, 01:07 AM   #15
Tomkay44   Tomkay44 is offline
The 2021 manual definitely say NOT screwed in for what that's worth.
