Are 428 Chains the same?
A follow up on my previous thread.
I got a new 428 chain, ( my previous chain broke). When I compare the new Chain to the old Chain, it appears to match pin for pin in size..but then about halfway down the chain I notice the pins don't match.. The old chain appears to be slightly longer. Question.. are all 428's the same? |
Old chain just has normal chain wear commonly known as "stretch". As the pins and bushings/rollers wear they get more play, which under tension makes the chain longer.
Thanks guys
When I changed the old chain on my used Zongshen Sierra (428HD/122), the length difference between the new and old chain was about 8 cm or 3". Needless to say, at that point I was all but running out of chain tension adjustment markers
![]() And yeah, all of the wear appeared to be concentrated in the pins and bushings. The links themselves appeared unworn, and the old chain also had quite a bit of slop and lateral bendiness between links. |
