#16 |
ok 0-25% throttle i got you.
there is a cap atthe top of the carb that the throttle cable goes to under that cap is a slider and a needle under that... you might need to watch a video how to take the cable off and not want to rip it apart as it takes practice to get these things off and on fast. once the needle is out of the slider change the clip position from 3(middle) to up one or down one if you move it up one it will lean out your bike at 0-25% throttle if you move it down one it will rich the bike at 0-25% throttle its a good thing to note you really should have access to a mixture screw when you do tuning.. overall if you want to fix the condition you should swap the carb
2013 Apollo 250RX -Zong db36 233cc engine w/ titanium valves, ported exh. -WizeCo 11:1 piston -CRF230 Athena big bore cylinder -Powercore 788 Exhaust -HF K&N Pod Filter and intake -1/4 fuel lines and valves w/ plastic tank -HR handle bars and MX pully controls -CRF230 SHOWA fork -Oversized MX brakes & rotors -17T 46T (3.07 Gear ratio) JT Sprockets with a D.I.D gold MX chain -Keihin pwk30 30mm carburetor 115main/35pilot |
#17 |
o shit wait dont do that !!!! i forgot they have the top cap disabled with a thread plug... ugh im not sure what to do with that stock carb with out tools.
if you can get the cap off then do what i suggested but if you dont get the thread lock off its going to rip the threads off and youll need to change it anyways
#18 |
ok so you dont know the stock jetting on that shit carb? its all good I will prob just put the mikuni knockoff in and go from the the supplied jets 100/42... adjust from there. Yeah im active on this forum and intend to be for the haul so I will be around. Thanks man
#19 |
Yeah Ill get the cap off ... no worries
#20 |
i robbed the stock carb for these bikes of the jets and the only two weird ones i have are the 112 and 39 so thats more likly the jets off the carb it comes with
definatly dont run the mikuni with a 100 main sir its will do almost the same as your dont like right now. just a heads up so you dont get frustrated because if you pull the carb for a change then when you rejet it because its not doing what you want youll be pulling it off again to do the jets. up to you of course just the leg work to do carb work on this bike can get tedious. hope the swap goes well post if ya need anything
#21 |
alright, ill swap in a 120 main and start from there. I will leave the plastics off once i start til i get it in range. again thanks for the info. I will advise ofc what I end up with. appreciate your and all replies
#22 | |
![]() Quote:
good luck man hope the tuning isnt a pain in the ass. Took me 26 times to fully feel confident i tried everything and picked my favorite set up for my configuration but the jet specs and tuning values i posted before are all from stock apollo 250rx owners with a mikuni vm26
#23 |
looked on orion for a plastic tank, and the only one listed doesnt look correct. Did you have to fab up some mounts for it or something? The link for the tank listed is https://www.orionpowersports.com/pla...0-and-z20-max/
or maybe the right tank is not being sold anymore... |
#24 |
Ok, so today my son got called in so the ride was scratched. I had nothing but time so I pulled the tank and plastic. Fought with that mickey mouse setup and finally got the garbage carb out. I wanted to see what jets were in it but only had a drill to work with so drilled off the base screws and pulled it apart. LOL, the jets in it have no indication for what size they are at all. So I put the clone carb with the 100 and 42 in the bike figuring it can't be any worse, sat the tank on it put a little go juice in and pushed the button. The bike fired right up and the throttle response is instant with no bog or other symptoms when on the gas. I have jets coming in a few days, and will adjust if needed.
#25 |
Had it apart today so snapped pics of the mod.
#26 | |
i sent you a link to the proper plastic tank and make sure you get a gas cap for it (rx) as it doesnt come with one. they arent cheap beware and dont forget the pool noodle for under the tank or youll be buying a new one if it wares out. once you get that carb and jets in it should feel like a different type of bike all together.
#27 |
No update on the apollo, waiting on some parts and stuff. Nothing was broken, well the bottom chain alignment/guard was mangled so I took that off but really just things I am going to change(jets, tank).
The xpro came in today, and I have to say that it is packaged more completely assembled and easier to wrestle out of the crate IMO(my son and I had it out of the crate and rolling on both wheels in 20 mins or so), but to be fair it is not 100% assembled. The engine in the xpro is at a different angle in the chassis and as such the kickstart is at an angle that leaves less travel, but seems adequate enough. The battery/air cleaner joint area is, uh, odd . I will follow up on the xpro filter/battery area after getting it all assembled which is on hold pending a carb, and a nice gash on my finger healing :( . I mentioned the chassis being diff on the xpro~ there is a good deal more room afforded on the xpro as the frame is just tubing instead of the slab of shaped medal down the side of the apollo and it appears carb tuning/maintenance would be much easier. More later. |
#28 | |
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
#29 | |
#30 |
ok got the xpro assembled today. I was waiting on jets and a carb but this bike has more room to work and seems easy, well easier to replace so why not slap it together right? Yeah so a few things: One of the battery brackets was missing, and after barely snugging the bolts in the handlebars one of them stripped. The nut was just spinning in place and the bars were still moveable if that gives an idea as to how loose the bolts were.... Trip to the local hardware and some grade 8 bolts later and those bars are tight!!! $10 fix. The battery bracket, well, i gave it some thought and they look like pipe hold downs so a few measurements and on the same trip grabbed a pack of 3/4 pipe hold downs and drilled a hole in the top and now that is fixed. The bike started pretty easily but wouldnt stay running without the choke being on half choke. Ok so its lean, I assumed it would be. It runs a bit better after warming but its def lean so the carb will be replaced, b/c the shit one in it is not worth modding to make it adjustable imo. Rode it around the house a few laps and it seems ok minus the feathering need due to the carb issue, although the suspension is really soft in the rear. I will adjust the shock once my spanner arrives and see if I can get that acceptable. Another week or so and I should have these out on the trails and will give a more in depth review/comparison along with some pics of the bikes and some Wyoming beauty in the background. One final note, I have not messed with the filters on either bike yet. I will oil them and see how much that helps the lean condition. I am sure it will some but I suspect that I will have to upgrade both and do some modding before I am comfortable with it.
