Lian or Lifan?
I'm tying to search Lian but, nothing. Loads of stuff comes up under Lifan 125cc though, even complete engine builds.. have you tried searching based off of engine number?
|2020 X-Pro Titan DLX| <-- FOR SALE!! |
most if not all chinese 125cc lifan engines are honda clones much like the zong 250cc engines. Some are made in different factories but all are the same casting intent to copy a honda design even some manufactures producing bikes to look like them also with there plastics. Most chinese bikes if used are abused and often dont get the same maintenance as someone who spent 6k to maintain a honda but thats not always the case. New these engines if broken in well and check over/maintained by a good knowledgeable person will last awhile and its often everything else on these unknown lifan bikes thats cheap not the motors. To get a good bike pick a chinese brand of dirt bike with good reviews like a apollo rfz or a hawk or venom or something at least then you know the little things wont break down faster then you can fix them.
hope this answers your question sir
2013 Apollo 250RX -Zong db36 233cc engine w/ titanium valves, ported exh. -WizeCo 11:1 piston -CRF230 Athena big bore cylinder -Powercore 788 Exhaust -HF K&N Pod Filter and intake -1/4 fuel lines and valves w/ plastic tank -HR handle bars and MX pully controls -CRF230 SHOWA fork -Oversized MX brakes & rotors -17T 46T (3.07 Gear ratio) JT Sprockets with a D.I.D gold MX chain -Keihin pwk30 30mm carburetor 115main/35pilot |
