Old 07-16-2021, 03:19 PM   #1
wtknstm   wtknstm is offline
2021 Taotao TBR7 Carb replacement
My 2021 TBR7 has a choke cable from the left handlebar to the carb - it allows for continuously variable choke adjustment. I would like to swap the factory (tamper proof) carb for one with conventional bowl screws.
I purchased a "cable choke" from amazon, but it does not have any provision for choke cable control (https://www.amazon.com/dp/B073SVJF2Q...roduct_details).
Can anyone suggest an alternative carb that has provisions for a cable choke to be used? The carb I purchased is described as a PZ30...
Thanks,
Old 07-16-2021, 03:31 PM   #2
Those so called tamperproof screws can be removed. Just slot the screws with a hack saw or Dremel then replace the screws with new ones.
Old 07-22-2021, 04:39 PM   #3
Drewpratt   Drewpratt is offline
I took slide off bc bike is way to lean and On the Tao tbr7 it has one slide slot? I ordered the nibbie 30 mm carb hoping it works out
Old 07-22-2021, 04:53 PM   #4
JerseyTBR7   JerseyTBR7 is offline
https://www.ebay.com/itm/324295819136
https://www.ebay.com/itm/111958216035
If at sea level, 110 main, 27.5 pilot, 1.5 turns out from fully seated on bottom fuel/air screw.
I also have the same 2021 TBR7 and it runs correct with this setup.
Old 07-22-2021, 05:20 PM   #5
What is a pod filter?direct ignition coil? Oil cooler?
Old 07-22-2021, 05:22 PM   #6
I steady bought the Nibbie 30 mm carb… hoping it works the box says Tao Apollo hawk 250
Old 07-22-2021, 06:30 PM   #7
CheapThrills   CheapThrills is offline
For the choke cable I found you have to transfer the old mount from the stock carb onto the new mount, or live without it.
- My 2 Bikes:
TaoTao TBR7
Boom Vader Gen 2 (BD125-10)
Testing a YouTube Channel
cable choke, pz30, tbr7
