07-13-2021, 03:49 AM | #1 |
Oil weight for my climate
I know oil threads can go real bad real fast, so I'll try to keep this one simple. My Lifan Xpect is on the way, and I plan to follow the commonly posted wisdom of changing the oil before ever starting it up, and then pretty damn frequently for the whole break in period.
I found a .pdf copy of the Xpect owner's manual, and predictably their guidance for oil weights isn't quite as detailed as I'd like. https://archive.org/details/american...age/3/mode/2up What I'm wondering about is if I should consider going with 20w-50 oil. We've been having a hotter than usual summer in my area so far this year. Set a new record high a few weeks ago (something like 115 IIRC), and it's been in the high 90s or over 100 pretty consistently since then as well. Does anyone know what this 200cc engine is a clone of so I can check that mfr specs? According to the lifan manual, their 15-40 is good for -10 to 40C, and google tells me 40C is 104 in freedom units. So I'm curious if this bike could benefit from 20W-50 oil during the peak summer months, and then maybe 10W-40 in fall/spring. |
07-13-2021, 07:43 AM | #2 |
20w-50 for the hot summers for sure.
07-13-2021, 09:53 AM | #3 |
You're getting an entire oil temperature chart with over 10 recommendations -how much more detail do you need? Granted, they probably ripped that chart off somewhere else, but at least they tell you more than the laconic "15W40 SF" that came with my bike (Zongshen Sierra)
They also threw some quite unusual viscosities in there (seriously, who uses 25W40?) and they don't mention anything in the xW-50 range, but it stands to reason that this would go even further -hotter- than xW-40. 20W-50 is OK for really hot climates, but you're going to regret it as soon as the oil gets used or the weather cools down a bit (but, if you plan on doing frequent changes, that doesn't matter much). A 15W50 would be a better option IMO, because it will be part-synthetic, while most 20W50s will be pure dino oil. Also, note no mention of MA/MA2 specs anywhere.... |
07-14-2021, 10:52 AM | #7 |
Since I asked "who uses 25W40 oil anyway?", I did some research and it seems that it's a very common weight for outboard/boat motors, and all the 25W40 oils that I could find were marine oils. Go figure.
