My Apollo 250rx
My apollo 250cc transformation:
*Yzf grips and levers *Exhaust wrap *Pwk 30mm smooth bore carb *UNI air filter *Cat delete *EGR delete *Ported and shaved head *E3 diamond fire electrode spark plug * Kx250 rear shock *12 tooth drive sprocket *adjustable timing CDI box |
Looking good! I like those levers
another PWK carb user lol you can call me friend
2013 Apollo 250RX -Zong db36 233cc engine w/ titanium valves, ported exh. -WizeCo 11:1 piston -CRF230 Athena big bore cylinder -Powercore 788 Exhaust -HF K&N Pod Filter and intake -1/4 fuel lines and valves w/ plastic tank -HR handle bars and MX pully controls -CRF230 SHOWA fork -Oversized MX brakes & rotors -17T 46T (3.07 Gear ratio) JT Sprockets with a D.I.D gold MX chain -Keihin pwk30 30mm carburetor 115main/35pilot |
250rx, apollo, db-36, db36, mods |
