07-04-2021, 01:59 PM | #1 |
Where to get gasket sets?
After googling 'cg 229 gasket set', I get alot of cg 125's and one cg 200-250 from Amazon--OUT OF STOCK--so does anyone know where to find the gasket sets?
I only need the side case gasket, as I'm planning on installing the 4 degree advance key. |
07-04-2021, 06:38 PM | #2 |
If you're careful you wont need another gasket changing that key.
07-04-2021, 07:01 PM | #4 |
Yeah, they say "cg 250", but a closer look at the gaskets and they don't appear to match a cg 229. There seems to be plenty of vertical CG 150's...is that compatible?
07-04-2021, 07:07 PM | #5 |
You would think that this is an easy to find product since 90% of US imported China-bikes use this engine. AARRGG!
07-04-2021, 07:13 PM | #6 |
I will be the guinea-pig and since it was only $8~ on Ebay I ordered this:
https://www.ebay.com/itm/32181386428....c100227.m3827 After investigating further, I ordered this and will compare the two (mostly the head gasket.) It's nice to have plenty of gaskets! https://www.ebay.com/itm/253539666887 Last edited by stewbrash; 07-05-2021 at 11:22 AM. |
07-04-2021, 07:16 PM | #7 |
a CG229 is a CG250 by all merits. Some gaskets are interchangable as the whole engine line up is based from the original Honda CG125...But there are some differences.
I purchased a generic CG250 kit and so far everything seems to fit. The head gasket was actually more of a 69mm than the 67mm. Side cover gaskets worked for me when I changed the stator side So i assume the clutch side will be fine. The red rocker cover gaskets for CG125s are undersized for Zongshen CG250 Rocker Covers Ive discovered. |
07-04-2021, 07:17 PM | #8 | |
Should be fine |
