Old 06-26-2021, 04:48 PM   #1
dugndeep   dugndeep is offline
Broken seat bracket
Started noticing the front of my seat seemingly awful loose,next thing you know that front bracket isn't even holding the front of the seat down.Took the seat off and seen that the bracket on the front was breaking.Bent it back together and tried to spot weld it without melting the plastic area there where the rivets hold the bracket.I got it temporarily fixed but will have to do something different when it breaks again.Still pondering what else I can do to strengthen it up.
File Type: jpg Broken seat bracket 1 2021-06-23 001.JPG (145.5 KB, 107 views)
File Type: jpg Broken seat bracket 1 2021-06-23 004.JPG (112.0 KB, 80 views)
File Type: jpg Broken seat bracket 1 2021-06-23 003.JPG (116.0 KB, 73 views)
Old 06-27-2021, 10:12 AM   #2
Might just drill those rivets out so I can get the bracket off to maybe weld it up better.Replace with a carriage bolt and nut.My welder goes down to 25 amps but still too much other than a spot weld on such thin material.
Old 06-27-2021, 10:45 AM   #3
Bruces   Bruces is offline
You can probably get a piece of a little thicker flat bar at Home Depot and make your own bracket easy enough .
Old 06-27-2021, 10:56 AM   #4
Here's the seat their showing on partskit.com that they say fits a Bull 200,it has a plastic front bracket.
