Old 03-05-2021, 05:12 PM   #1
Stock mirrors on Brozz ?
I have the Brozz 250 sport , and I just can't get my mirrors to adjust in a position that does me any good. I can sometimes see what's way behind me , but in general I am very unsatisfied with mirror adjustment. The only solution I can think of would be the mirrors set wider apart. Do you fellow dual sport owners have this issue? ,Do you replace the mirrors with something that provides a better, closer rear view picture? Am I just not adjusting them correctly? I would appreciate any advice, because I hate to even stop, or especially turn left with the way they currently are. I am talking about turning on an unbroken line, but I still don't like the thought of it without knowing what's happening behind me.
Old 03-05-2021, 06:05 PM   #2
Are you only adjusting at the top? Have you tried to adjust the angle of the stems at the base? I am a pretty broad shouldered guy and I could get a decent view from the stock Hawk mirrors after adjusting the stems to give me a better adjustment angle on the mirrors up top.
Old 03-05-2021, 06:06 PM   #3
I may have resolved my issue, or at least made it tolerable. I went out to put my bike away, and I figured I would position it in front of my truck . I still couldn't get the picture I wanted, and then I noticed that the bar part of each mirror could be adjusted to give me just a wee little bit more width on each side, and that miniscule amount on each side helped immensely. I could see my truck in each mirror. It looked like my truck was off to my left ,instead of directly behind me, when I was looking through my left mirror, but I can get used to that. The truck looked like it was behind me when I looked through the right mirror.
Old 03-05-2021, 06:07 PM   #4
Spins   Spins is offline
Spins's Avatar
The stock mirrors are so..so.. I’ve adjusted mine a few times. I usually have to pull my arms in or shift my body to see, especially if I’m wearing a jacket my shoulders get in the way. Adjustment of your bars and mounts for the mirrors will effect things as well. Did you install aftermarket bars which might be lower?
2019 Z 400
2020 Tan Recon
2021 KLX 300
2022 GPX FSE 450R
Old 03-05-2021, 06:08 PM   #5
Thanks Dan. I was evidently typing when you answered my question. It was the fact that the stems were out of adjustment. Rhanks
Old 03-05-2021, 06:11 PM   #6
Spins, I have been wearing an insulated blaze orange hunting jacket, mainly for visibility due to me being inexperienced.
Old 06-06-2021, 11:20 PM   #7
DSM   DSM is offline
I’ve found the TBR7 stock mirrors to be crap. They will not stay put regardless of how tight I screw them down.
Is there a cheap alternative?
I’m considering glueing them in place.
Old 06-07-2021, 04:19 AM   #8
TxTaoRider   TxTaoRider is offline
I've got these and really like them: https://www.ebay.com/itm/Emgo-Univer....m46890.l49286
2021 Tao Tbr7 - "Lucille"
Mods so far- Brozz swingarm, 21" front rim (Bridgestone Tw302 rear/Dunlop D606 front tires), Digital gauge cluster, pz30b pumper carb, after market hand guards, aftermarket brake and clutch levers, round fold away mirrors, Fly handlebars shortened slightly, 13t front sprocket
2009 Q-link Legacy 250
1982 Suzuki GS1100ES - "Jolene"
Old 06-07-2021, 08:54 AM   #9
bogieboy's Avatar
i couldnt see squat out of m stock mirrors on my Roketa, being supermoto'd, i went for these...https://www.amazon.com/gp/product/B08GC76V7K i dont think i will ever go back to stalk mirrors... i had a similar pair on the bike for 8 yrs but i i snapped one off getting the bike out of storage, hence the current replacement.
Old 06-07-2021, 08:58 AM   #10
herbie   herbie is offline
I had the same problem with my Brozz after I assembled it. I thought i would try and switch mirrors from one side to the other and walla they adjust just like they are supposed to. Hope this helps
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 06-07-2021, 09:11 AM   #11
I have gotten used to my mirrors. I think a lot had to do with my riding position, and lack of expierence . I think I was sitting too far forward, and riding hunkered down . I do catch myself leaning back to get a better view from my mirrors at times, but I generally see good enough with the stock mirrors now.
Old 06-07-2021, 12:32 PM   #12
I honestly was looking to purchase different mirrors because I couldn't adjust the darn things where I could see good out of them, and I have a lot of mc experience. I never thought about at the time that there might be a left and right mirror but on the Brozz it does make a difference. After I switched sides I had all the adjustment I needed, it might be worth a try, it doesn't take long to switch them
1978 Kawasaki KL250
Old 06-07-2021, 02:15 PM   #13
DSM   DSM is offline
Thanks! I have a set on the way.
